Guardian87 4 Posted July 20, 2021 Posted July 20, 2021 I changed my library setup to look at symbolic links, which then link to different hard drives in the background. Since I did that, adding files doesn't automatically trigger a library scan and I do this manually at the moment. Is my assumption correct, that this is caused by symbolic links or do I have to look for something else? 1
Carlo 4561 Posted July 20, 2021 Posted July 20, 2021 This is likely caused by the Symbolic links. You would be better off adding the different paths directly to the library in question.
Guardian87 4 Posted July 20, 2021 Author Posted July 20, 2021 Thanks for the feedback. I split up the underlying hard drives and really wasn’t keen on readding the entire library and so on. So I imagine there is no easy way to make it work with symbolic links?
Guardian87 4 Posted July 20, 2021 Author Posted July 20, 2021 Raspbian, the Debian Version for raspberrypi.
Carlo 4561 Posted July 20, 2021 Posted July 20, 2021 Sorry, got nothing for you on that platform as I don't know it. Sorry about that!
Luke 42184 Posted July 20, 2021 Posted July 20, 2021 Support is limited based on what the .net core runtime supports: https://github.com/dotnet/runtime/issues/24655 https://github.com/dotnet/runtime/issues/24271 However it appears there has finally been some movement, so following the release of .net core 6, that hopefully means a future version of Emby Server should be able to more easily support them. 1
TheShanMan 41 Posted June 8, 2024 Posted June 8, 2024 @LukeWith the .net runtime giving you what you need some time ago, is there any hope of supporting symbolic links soon? I have some library annoyances that I hoped to solve by making use of symbolic links. However, I'm seeing that while most of my libraries appear to work perfectly with symbolic links, a few silently fail to scan (no errors or anything relating to file paths in log) resulting in a library of zero items. I'm on Windows if that matters.
Luke 42184 Posted June 8, 2024 Posted June 8, 2024 1 hour ago, TheShanMan said: @LukeWith the .net runtime giving you what you need some time ago, is there any hope of supporting symbolic links soon? I have some library annoyances that I hoped to solve by making use of symbolic links. However, I'm seeing that while most of my libraries appear to work perfectly with symbolic links, a few silently fail to scan (no errors or anything relating to file paths in log) resulting in a library of zero items. I'm on Windows if that matters. It would require some restructuring but yes it's doable.
TheShanMan 41 Posted June 8, 2024 Posted June 8, 2024 How soon do you think that would be possible? I don't want to get my hopes up if it's a pipe dream that has no realistic chance of being worked on anytime soon.
Luke 42184 Posted June 8, 2024 Posted June 8, 2024 2 hours ago, TheShanMan said: How soon do you think that would be possible? I don't want to get my hopes up if it's a pipe dream that has no realistic chance of being worked on anytime soon. I can’t really say at this time, sorry.
TheShanMan 41 Posted June 8, 2024 Posted June 8, 2024 Which probably means "don't hold your breath". Haha. I spent quite a few hours writing and testing a script to create a new directory structure of symlinks from my existing structure based on a small sample size working well. So it's disappointing to find that it randomly just doesn't work in some cases. I won't die without it though. Thanks Luke.
