saunderslambert 1 Posted July 20, 2021 Posted July 20, 2021 (edited) Is there an android app that can play dolby vision content on shield tv pro 2019,Thanks Edited July 20, 2021 by saunderslambert Mispell
Carlo 4561 Posted July 20, 2021 Posted July 20, 2021 (edited) Hi, Our Android ATV app already support this but you have to have the proper Dolby Vision equipment connected to your Shield TV. You may want to check these settings: https://www.nvidia.com/en-us/shield/support/shield-tv/enable-dolby-vision-hdr10-on-shield/ Edited July 20, 2021 by cayars
rbjtech 5344 Posted July 22, 2021 Posted July 22, 2021 To add - there are also many flavours of Dolby Vision - and depending on the media format and construction (MKV, MP4 etc and Dolby Vision Profiles and Layers..) they may not necessarily work. The good news is you have the very best end user client capable of playing DV - so if the Shield Pro 2019 does not play it as DV, then it's almost certainly a media format or layering issue. 1
lightsout 156 Posted July 28, 2021 Posted July 28, 2021 Do I need a beta or does the main app work with DV?
Luke 42246 Posted July 29, 2021 Posted July 29, 2021 13 hours ago, lightsout said: Do I need a beta or does the main app work with DV? The main version of the app supports dv. 1
saunderslambert 1 Posted July 29, 2021 Author Posted July 29, 2021 Hi what is the Best android app, which can play dolby vision content on shield tv pro 2019.For example,"VLC,MXplayer,Kodi" None of these examples Can. The Only one i can find so far is (Just(video)Player).Which can play dolby vision content on shield tv pro 2019,Thanks
ebr 16338 Posted July 29, 2021 Posted July 29, 2021 Hi. Our app without any of those other players can play DV within the constraints Cayars mentioned above.
saunderslambert 1 Posted July 29, 2021 Author Posted July 29, 2021 (edited) Thanks what do you mean by our app what is our app?,Rob. shield tv pro 2019 is not an app!.Dolby vision is enabled on my shield tv pro.In order to play dolby vision file.You need an app to play it on. Edited July 29, 2021 by saunderslambert Mispell 1
vdatanet 1619 Posted July 29, 2021 Posted July 29, 2021 12 minutes ago, saunderslambert said: Thanks what do you mean by our app what is our app?,Rob. shield tv pro 2019 is not an app! @ebr is talking about this app: Emby for NVIDIA Shield - Emby 1
crusher11 1143 Posted July 29, 2021 Posted July 29, 2021 People wandering in here thinking Emby supplies media and trying to figure out how to access it is one thing, but people wandering in here who don't know Emby exists is a brand new one. 1
