alext41 4 Posted July 20, 2021 Posted July 20, 2021 Hi, first of all great work and guide. All went smooth on the upgrade. Maybe one thing you should write down that you must also give the emby internal user rights to the folder where the backup will be stored. The main question for me what should I do with the "old" /volume1/Emby/* folder? Is it save to delete it? thx for the help alex
Solution Carlo 4561 Posted July 20, 2021 Solution Posted July 20, 2021 Yes, once your migration is good/verified and you need to free up space you can remove the old location. If you're not pressed for space, you might want to leave it around a bit, sort of as a complete system backup that could be used in an emergency. 1
