bsmith2400 0 Posted July 18, 2021 Posted July 18, 2021 Ok I’m try to get my main Tv up and going… I’m running Emby Premier on a Fire TV. I’m trying to stream my content from Ultra.cc seedbox to Houston Tx. Emby works perfectly on my MacBook and IPhone no problem at all on the stream on these devices However on my main TV (same setup and network) Emby just spins and never loads? We’re should a start? Im sure a transcoding thing and looked into the setting without much luck. Do I need to change something on the Emby app or the Seedbox control panel? For example Black Widows works great on MacBook and iPhone..but no luck on the fire tv? Any help would be appreciated.. Thanks, Brandon
ebr 16338 Posted July 18, 2021 Posted July 18, 2021 Hi. Can we please see the logs from this example? Thanks.
bsmith2400 0 Posted July 18, 2021 Author Posted July 18, 2021 https://www.dropbox.com/sh/tbkbx3ewo8wyi46/AABjgZYlVZ4hDYn4T_xKa53_a?dl=0 There seems to be about 56 logs... Does the last 20 work? Let me know your thoughts or you need something else. Thanks, Brandon
ebr 16338 Posted July 19, 2021 Posted July 19, 2021 Hi. Please follow the instructions in that post to give us just the logs indicating the issue as well as a description of what you did during the session and what happened. Also, please send a log from the app as indicated there. Thanks!
