TristanX 0 Posted July 17, 2021 Posted July 17, 2021 I am using the application Skybox on the Oculus Quest 2 vr headset to access emby's DLNA server .... when I do so and try to play a movie or tv show, about 50% of the time, it will crash the Quest 2 network connection. This works fine with other DLNA servers I have tested. I have attached the server log from the last occurrence, and it took place around 1500 hours or so. Thanks for any assistance you can provide. embyserver.txt
TristanX 0 Posted July 17, 2021 Author Posted July 17, 2021 (edited) I can repro this behavior quite readily so if you need more logging, or debug logs, etc, I can generate them for you. Thanks again for any help. Edited July 17, 2021 by TristanX
Luke 42237 Posted July 20, 2021 Posted July 20, 2021 Hi, and this only happens when you start playing something, right? 1
TristanX 0 Posted July 20, 2021 Author Posted July 20, 2021 Yes, but I am now having trouble getting this to reproduce, I'm thinking maybe it was a networking issue in reality, and not Emby server at all. I apologize, I will keep trying to reproduce it, and I will post back if and when I do. Again, I am sorry to have taken up your time.
Luke 42237 Posted July 20, 2021 Posted July 20, 2021 OK thanks for the info. Let us know if you find out anything more.
