Jerren 18 Posted August 19, 2021 Author Posted August 19, 2021 I did it through command line like mrobi outlined once. Odd thing about this whole thing is that the first time i started having this strange pauzing thing was only when playing something through the chromecast never on the webclient. Now it's on the webclient (haven't used my chromecast in a bit so no idea on that one) which didn't happen in the past. Sadly it's just as frequent, since making the previous post i've had it happen 6 or 7 times more, i'll post another log, the last pauze on it should be from me actually intentionally pauzing it and moving to the log section. embyserver.txt
Jerren 18 Posted August 19, 2021 Author Posted August 19, 2021 Just for clarity i'll say how i installed through command line in Truenas 12 completely. Go to jails -> add Give a name, point to the release version, give an ip adress. ( in case this is the second emby you make make sure to tick the vnet box) Then install dependencies (paste this in the shell of the jail): pkg install mono libass fontconfig freetype2 fribidi gnutls iconv opus sqlite3 libtheora libva libvpx libvorbis webp libx264 x265 dav1d libzvbi libraw ImageMagick6 then if any mismatches show up say yes to ignore them ( unless ofcourse you know of a reason not to ignore them) Then go to https://github.com/MediaBrowser/Emby.Releases/releases/ and copy the latest .txz link, go back to the shell and put in the following (obviously replace the link version with whatever is current): pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.5.4.0/emby-server-freebsd12_4.5.4.0_amd64.txz After that you put in; sysrc emby_server_enable="YES" And lastly follow it up with service emby-server start To update emby through commandline on Truenas 12 again go to the the jail section, go to emby's jail and click on the shell to input these commands. service emby-server stop pkg update pkg upgrade pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.6.4.0/emby-server-freebsd12_4.6.4.0_amd64.txz service emby-server start Again if any mismatches then say Y for yes unless you know you shouldn't. And that's the install and update procedure i use for emby.
Jerren 18 Posted August 20, 2021 Author Posted August 20, 2021 Figured i would give an update before going to sleep, happened around 8 more times. It doesn't happen on the same timestamp every time so i don't think it's a problem with the file. It also doesn't seem to be timebase as i could sometimes watch fine for 20 minutes then have pauzes every 5 seconds or every minute. Figured i would give the latest logs in emby. ffmpeg-remux-dc0822b5-7dd7-43d4-9f42-9c3036047e15_1.txtembyserver.txt
Solution Luke 42238 Posted August 21, 2021 Solution Posted August 21, 2021 Quote Then go to https://github.com/MediaBrowser/Emby.Releases/releases/ and copy the latest .txz link, go back to the shell and put in the following (obviously replace the link version with whatever is current): pkg add -f https://github.com/MediaBrowser/Emby.Releases/releases/download/4.5.4.0/emby-server-freebsd12_4.5.4.0_amd64.txz No, use the newer .pkg file instead.
Jerren 18 Posted August 21, 2021 Author Posted August 21, 2021 (edited) Ah what's the difference? Since the .txz worked and they seem to be released at the same time? Edited August 21, 2021 by jerren
Jerren 18 Posted August 23, 2021 Author Posted August 23, 2021 No since i didn't know what the difference was. Can i just use the link and update my installed emby-server-freebsd12_4.6.4.0_amd64.txz with emby-server-freebsd12_4.6.4.0_amd64.pkg? Or do i need to do a fresh install?
Luke 42238 Posted August 24, 2021 Posted August 24, 2021 Yes you can do that. You don't need to do a fresh install.
Jerren 18 Posted August 26, 2021 Author Posted August 26, 2021 Did the update with the .pkg link, will post back if i get it again.
Luke 42238 Posted August 26, 2021 Posted August 26, 2021 19 minutes ago, jerren said: Did the update with the .pkg link, will post back if i get it again. Great, thanks.
