jmorris644 0 Posted July 17, 2021 Posted July 17, 2021 I just purchased a new Bel-Canto system. I can see and select the system to render to it but when I hit "play" nothing happens. Below is the error that I see in the log. 2021-07-17 02:37:55.933 Debug Dlna: Belcanto Renderer-137 - Received PlayRequest: PlayNow 2021-07-17 02:37:55.935 Info Dlna: Using default profile for: DeviceDescription: FriendlyName:Belcanto Renderer-137 Manufacturer:Belcanto ManufacturerUrl:http://www.belcantodesign.com ModelDescription:MR-MOD ModelName:MR-MOD ModelNumber:1.0 ModelUrl:http://www.abc-pcb.ch SerialNumber:0280AD2302A6 2021-07-17 02:37:55.935 Debug Dlna: Dlna Device.GetConnectionManagerProtocolAsync 2021-07-17 02:37:55.935 Debug HttpClient: GET http://192.168.1.137:49152/dmr/cmscpd.xml 2021-07-17 02:37:55.938 Error HttpClient: <html><body><h1>404 Not Found</h1></body></html> 2021-07-17 02:37:55.946 Error Server: Error processing request *** Error Report ***
Luke 42237 Posted July 17, 2021 Posted July 17, 2021 Hi there, please attach the complete emby server log file. thanks.
jmorris644 0 Posted July 18, 2021 Author Posted July 18, 2021 It's a high end pre-amp with dual mono amps. Search bel-canto black system
Luke 42237 Posted July 20, 2021 Posted July 20, 2021 OK I've pushed a 1.0.68 update to the Emby Dlna plugin. This will add more logging to help me identify the problem. Once you have that, please restart Emby Server, then try again and then attach the latest emby server log. thanks.
jmorris644 0 Posted July 20, 2021 Author Posted July 20, 2021 Over the weekend I did reload Mac OS onto the mini. Same issue that I was having on Ubuntu. I have attached the new log file. embyserver.txt
Luke 42237 Posted July 20, 2021 Posted July 20, 2021 can you put these two urls into a browser: http://192.168.1.137:49152/amr.xml http://192.168.1.137:49152/dmr/avtscpd.xml And then provide me with the contents of what they respond with. Thanks.
jmorris644 0 Posted July 20, 2021 Author Posted July 20, 2021 This XML file does not appear to have any style information associated with it. The document tree is shown below. <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <URLBase>http://192.168.1.137:49152/</URLBase> <device> <deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType> <friendlyName>Belcanto Renderer-137</friendlyName> <manufacturer>Belcanto</manufacturer> <manufacturerURL>http://www.belcantodesign.com</manufacturerURL> <modelDescription>MR-MOD</modelDescription> <modelName>MR-MOD</modelName> <modelNumber>1.0</modelNumber> <modelURL>http://www.abc-pcb.ch</modelURL> <serialNumber>0280AD2302A6</serialNumber> <UDN>uuid:0280AD2302A6-Belcanto Renderer</UDN> <UPC>123456789</UPC> <serviceList> <service> <serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType> <serviceId>urn:upnp-org:serviceId:RenderingControl1</serviceId> <SCPDURL>rcscpd.xml</SCPDURL> <controlURL>/upnp/control/RenderingControl</controlURL> <eventSubURL>/upnp/event/RenderingControl</eventSubURL> </service> <service> <serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType> <serviceId>urn:upnp-org:serviceId:AVTransport1</serviceId> <SCPDURL>avtscpd.xml</SCPDURL> <controlURL>/upnp/control/AVTransport</controlURL> <eventSubURL>/upnp/event/AVTransport</eventSubURL> </service> <service> <serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType> <serviceId>urn:upnp-org:serviceId:ConnectionManager1</serviceId> <SCPDURL>cmscpd.xml</SCPDURL> <controlURL>/upnp/control/ConnectionManager</controlURL> <eventSubURL>/upnp/event/ConnectionManager</eventSubURL> </service> </serviceList> <presentationURL>index.html</presentationURL> </device> </root> The 2nd URL got a 404 File Not Found Quote
Luke 42237 Posted July 20, 2021 Posted July 20, 2021 What about http://192.168.1.137:49152/avtscpd.xml
jmorris644 0 Posted July 20, 2021 Author Posted July 20, 2021 (edited) That got the 404 file not found error Edited July 20, 2021 by jmorris644
Luke 42237 Posted July 20, 2021 Posted July 20, 2021 1 hour ago, jmorris644 said: That got the 404 file not found error Are you sure? that's not the same as what I asked you to try earlier.
jmorris644 0 Posted July 21, 2021 Author Posted July 21, 2021 I humbly apologize. I thought it was the same as the second one. Here is the response. This XML file does not appear to have any style information associated with it. The document tree is shown below. <scpd xmlns="urn:schemas-upnp-org:service-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <actionList> <action> <name>Play</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>Speed</name> <direction>in</direction> <relatedStateVariable>TransportPlaySpeed</relatedStateVariable> </argument> </argumentList> </action> <action> <name>Stop</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> </argumentList> </action> <action> <name>Next</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> </argumentList> </action> <action> <name>Previous</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> </argumentList> </action> <action> <name>SetNextAVTransportURI</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>NextURI</name> <direction>in</direction> <relatedStateVariable>NextAVTransportURI</relatedStateVariable> </argument> <argument> <name>NextURIMetaData</name> <direction>in</direction> <relatedStateVariable>NextAVTransportURIMetaData</relatedStateVariable> </argument> </argumentList> </action> <action> <name>GetMediaInfo</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>NrTracks</name> <direction>out</direction> <relatedStateVariable>NumberOfTracks</relatedStateVariable> </argument> <argument> <name>MediaDuration</name> <direction>out</direction> <relatedStateVariable>CurrentMediaDuration</relatedStateVariable> </argument> <argument> <name>CurrentURI</name> <direction>out</direction> <relatedStateVariable>AVTransportURI</relatedStateVariable> </argument> <argument> <name>CurrentURIMetaData</name> <direction>out</direction> <relatedStateVariable>AVTransportURIMetaData</relatedStateVariable> </argument> <argument> <name>NextURI</name> <direction>out</direction> <relatedStateVariable>NextAVTransportURI</relatedStateVariable> </argument> <argument> <name>NextURIMetaData</name> <direction>out</direction> <relatedStateVariable>NextAVTransportURIMetaData</relatedStateVariable> </argument> <argument> <name>PlayMedium</name> <direction>out</direction> <relatedStateVariable>PlaybackStorageMedium</relatedStateVariable> </argument> <argument> <name>RecordMedium</name> <direction>out</direction> <relatedStateVariable>RecordStorageMedium</relatedStateVariable> </argument> <argument> <name>WriteStatus</name> <direction>out</direction> <relatedStateVariable>RecordMediumWriteStatus</relatedStateVariable> </argument> </argumentList> </action> <action> <name>GetDeviceCapabilities</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>PlayMedia</name> <direction>out</direction> <relatedStateVariable>PossiblePlaybackStorageMedia</relatedStateVariable> </argument> <argument> <name>RecMedia</name> <direction>out</direction> <relatedStateVariable>PossibleRecordStorageMedia</relatedStateVariable> </argument> <argument> <name>RecQualityModes</name> <direction>out</direction> <relatedStateVariable>PossibleRecordQualityModes</relatedStateVariable> </argument> </argumentList> </action> <action> <name>SetAVTransportURI</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>CurrentURI</name> <direction>in</direction> <relatedStateVariable>AVTransportURI</relatedStateVariable> </argument> <argument> <name>CurrentURIMetaData</name> <direction>in</direction> <relatedStateVariable>AVTransportURIMetaData</relatedStateVariable> </argument> </argumentList> </action> <action> <name>SetPlayMode</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>NewPlayMode</name> <direction>in</direction> <relatedStateVariable>CurrentPlayMode</relatedStateVariable> </argument> </argumentList> </action> <action> <name>GetCurrentTransportActions</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>Actions</name> <direction>out</direction> <relatedStateVariable>CurrentTransportActions</relatedStateVariable> </argument> </argumentList> </action> <action> <name>GetTransportSettings</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>PlayMode</name> <direction>out</direction> <relatedStateVariable>CurrentPlayMode</relatedStateVariable> </argument> <argument> <name>RecQualityMode</name> <direction>out</direction> <relatedStateVariable>CurrentRecordQualityMode</relatedStateVariable> </argument> </argumentList> </action> <action> <name>GetTransportInfo</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>CurrentTransportState</name> <direction>out</direction> <relatedStateVariable>TransportState</relatedStateVariable> </argument> <argument> <name>CurrentTransportStatus</name> <direction>out</direction> <relatedStateVariable>TransportStatus</relatedStateVariable> </argument> <argument> <name>CurrentSpeed</name> <direction>out</direction> <relatedStateVariable>TransportPlaySpeed</relatedStateVariable> </argument> </argumentList> </action> <action> <name>Pause</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> </argumentList> </action> <action> <name>Seek</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>Unit</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_SeekMode</relatedStateVariable> </argument> <argument> <name>Target</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_SeekTarget</relatedStateVariable> </argument> </argumentList> </action> <action> <name>GetPositionInfo</name> <argumentList> <argument> <name>InstanceID</name> <direction>in</direction> <relatedStateVariable>A_ARG_TYPE_InstanceID</relatedStateVariable> </argument> <argument> <name>Track</name> <direction>out</direction> <relatedStateVariable>CurrentTrack</relatedStateVariable> </argument> <argument> <name>TrackDuration</name> <direction>out</direction> <relatedStateVariable>CurrentTrackDuration</relatedStateVariable> </argument> <argument> <name>TrackMetaData</name> <direction>out</direction> <relatedStateVariable>CurrentTrackMetaData</relatedStateVariable> </argument> <argument> <name>TrackURI</name> <direction>out</direction> <relatedStateVariable>CurrentTrackURI</relatedStateVariable> </argument> <argument> <name>RelTime</name> <direction>out</direction> <relatedStateVariable>RelativeTimePosition</relatedStateVariable> </argument> <argument> <name>AbsTime</name> <direction>out</direction> <relatedStateVariable>AbsoluteTimePosition</relatedStateVariable> </argument> <argument> <name>RelCount</name> <direction>out</direction> <relatedStateVariable>RelativeCounterPosition</relatedStateVariable> </argument> <argument> <name>AbsCount</name> <direction>out</direction> <relatedStateVariable>AbsoluteCounterPosition</relatedStateVariable> </argument> </argumentList> </action> </actionList> <serviceStateTable> <stateVariable sendEvents="no"> <name>CurrentPlayMode</name> <dataType>string</dataType> <allowedValueList> <allowedValue>NORMAL</allowedValue> <allowedValue>REPEAT_ALL</allowedValue> <allowedValue>INTRO</allowedValue> </allowedValueList> <defaultValue>NORMAL</defaultValue> </stateVariable> <stateVariable sendEvents="no"> <name>RecordStorageMedium</name> <dataType>string</dataType> <allowedValueList> <allowedValue>UNKNOWN</allowedValue> <allowedValue>DV</allowedValue> <allowedValue>MINI-DV</allowedValue> <allowedValue>VHS</allowedValue> <allowedValue>W-VHS</allowedValue> <allowedValue>S-VHS</allowedValue> <allowedValue>D-VHS</allowedValue> <allowedValue>VHSC</allowedValue> <allowedValue>VIDEO8</allowedValue> <allowedValue>HI8</allowedValue> <allowedValue>CD-ROM</allowedValue> <allowedValue>CD-DA</allowedValue> <allowedValue>CD-R</allowedValue> <allowedValue>CD-RW</allowedValue> <allowedValue>VIDEO-CD</allowedValue> <allowedValue>SACD</allowedValue> <allowedValue>MD-AUDIO</allowedValue> <allowedValue>MD-PICTURE</allowedValue> <allowedValue>DVD-ROM</allowedValue> <allowedValue>DVD-VIDEO</allowedValue> <allowedValue>DVD-R</allowedValue> <allowedValue>DVD+RW</allowedValue> <allowedValue>DVD-RW</allowedValue> <allowedValue>DVD-RAM</allowedValue> <allowedValue>DVD-AUDIO</allowedValue> <allowedValue>DAT</allowedValue> <allowedValue>LD</allowedValue> <allowedValue>HDD</allowedValue> <allowedValue>MICRO-MV</allowedValue> <allowedValue>NETWORK</allowedValue> <allowedValue>NONE</allowedValue> <allowedValue>NOT_IMPLEMENTED</allowedValue> <allowedValue> vendor-defined </allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="yes"> <name>LastChange</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>RelativeTimePosition</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentTrackURI</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentTrackDuration</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentRecordQualityMode</name> <dataType>string</dataType> <allowedValueList> <allowedValue>0:EP</allowedValue> <allowedValue>1:LP</allowedValue> <allowedValue>2:SP</allowedValue> <allowedValue>0:BASIC</allowedValue> <allowedValue>1:MEDIUM</allowedValue> <allowedValue>2:HIGH</allowedValue> <allowedValue>NOT_IMPLEMENTED</allowedValue> <allowedValue> vendor-defined </allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentMediaDuration</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>AbsoluteCounterPosition</name> <dataType>i4</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>RelativeCounterPosition</name> <dataType>i4</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>A_ARG_TYPE_InstanceID</name> <dataType>ui4</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>AVTransportURI</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>TransportState</name> <dataType>string</dataType> <allowedValueList> <allowedValue>STOPPED</allowedValue> <allowedValue>PAUSED_PLAYBACK</allowedValue> <allowedValue>PAUSED_RECORDING</allowedValue> <allowedValue>PLAYING</allowedValue> <allowedValue>RECORDING</allowedValue> <allowedValue>TRANSITIONING</allowedValue> <allowedValue>NO_MEDIA_PRESENT</allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentTrackMetaData</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>NextAVTransportURI</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>PossibleRecordQualityModes</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentTrack</name> <dataType>ui4</dataType> <allowedValueRange> <minimum>0</minimum> <maximum>4294967295</maximum> <step>1</step> </allowedValueRange> </stateVariable> <stateVariable sendEvents="no"> <name>AbsoluteTimePosition</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>NextAVTransportURIMetaData</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>PlaybackStorageMedium</name> <dataType>string</dataType> <allowedValueList> <allowedValue>UNKNOWN</allowedValue> <allowedValue>DV</allowedValue> <allowedValue>MINI-DV</allowedValue> <allowedValue>VHS</allowedValue> <allowedValue>W-VHS</allowedValue> <allowedValue>S-VHS</allowedValue> <allowedValue>D-VHS</allowedValue> <allowedValue>VHSC</allowedValue> <allowedValue>VIDEO8</allowedValue> <allowedValue>HI8</allowedValue> <allowedValue>CD-ROM</allowedValue> <allowedValue>CD-DA</allowedValue> <allowedValue>CD-R</allowedValue> <allowedValue>CD-RW</allowedValue> <allowedValue>VIDEO-CD</allowedValue> <allowedValue>SACD</allowedValue> <allowedValue>MD-AUDIO</allowedValue> <allowedValue>MD-PICTURE</allowedValue> <allowedValue>DVD-ROM</allowedValue> <allowedValue>DVD-VIDEO</allowedValue> <allowedValue>DVD-R</allowedValue> <allowedValue>DVD+RW</allowedValue> <allowedValue>DVD-RW</allowedValue> <allowedValue>DVD-RAM</allowedValue> <allowedValue>DVD-AUDIO</allowedValue> <allowedValue>DAT</allowedValue> <allowedValue>LD</allowedValue> <allowedValue>HDD</allowedValue> <allowedValue>MICRO-MV</allowedValue> <allowedValue>NETWORK</allowedValue> <allowedValue>NONE</allowedValue> <allowedValue>NOT_IMPLEMENTED</allowedValue> <allowedValue> vendor-defined </allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="no"> <name>CurrentTransportActions</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>RecordMediumWriteStatus</name> <dataType>string</dataType> <allowedValueList> <allowedValue>WRITABLE</allowedValue> <allowedValue>PROTECTED</allowedValue> <allowedValue>NOT_WRITABLE</allowedValue> <allowedValue>UNKNOWN</allowedValue> <allowedValue>NOT_IMPLEMENTED</allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="no"> <name>PossiblePlaybackStorageMedia</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>AVTransportURIMetaData</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>NumberOfTracks</name> <dataType>ui4</dataType> <allowedValueRange> <minimum>0</minimum> <maximum>4294967295</maximum> </allowedValueRange> </stateVariable> <stateVariable sendEvents="no"> <name>A_ARG_TYPE_SeekMode</name> <dataType>string</dataType> <allowedValueList> <allowedValue>ABS_TIME</allowedValue> <allowedValue>REL_TIME</allowedValue> <allowedValue>ABS_COUNT</allowedValue> <allowedValue>REL_COUNT</allowedValue> <allowedValue>TRACK_NR</allowedValue> <allowedValue>CHANNEL_FREQ</allowedValue> <allowedValue>TAPE-INDEX</allowedValue> <allowedValue>FRAME</allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="no"> <name>A_ARG_TYPE_SeekTarget</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>PossibleRecordStorageMedia</name> <dataType>string</dataType> </stateVariable> <stateVariable sendEvents="no"> <name>TransportStatus</name> <dataType>string</dataType> <allowedValueList> <allowedValue>OK</allowedValue> <allowedValue>ERROR_OCCURRED</allowedValue> <allowedValue> vendor-defined </allowedValue> </allowedValueList> </stateVariable> <stateVariable sendEvents="no"> <name>TransportPlaySpeed</name> <dataType>string</dataType> <allowedValueList> <allowedValue>1</allowedValue> <allowedValue> vendor-defined </allowedValue> </allowedValueList> </stateVariable> </serviceStateTable> </scpd>
Luke 42237 Posted July 21, 2021 Posted July 21, 2021 Ok please try the 1.0.69 update to the Dlna plugin. Thanks.
jmorris644 0 Posted July 23, 2021 Author Posted July 23, 2021 It is working!! Thanks so much. I had to delete the DLNA plugin and reinstall. Is that the only to do an update of a plugin? Also, pulling in my other thread question into here. Is there a way to output through the USB port from the emby server? Thanks Joe
Luke 42237 Posted July 23, 2021 Posted July 23, 2021 No, the server will update plugins for you automatically. I don't see how USB output would be possible, sorry.
