mcb276084423 0 Posted August 13, 2021 Author Posted August 13, 2021 Hello, I asked the engineers of Synology. They said that the certificate of https://mb3admin.com is expired. And when I visit https://mb3admin.com with the webpage, it will automatically be redirected to https://emby.media, and when I try to ping mb3admin.com in nas, the IP address pointed to is 119.28.51.30 And the correct one should be ...
mcb276084423 0 Posted August 13, 2021 Author Posted August 13, 2021 Already, the problem is found because the NAS's hosts analysis file has a message of 119.28.51.30 mb3admin.com, so no matter what method I use, it will point to this IP.
Carlo 4561 Posted August 13, 2021 Posted August 13, 2021 I'm not sure how the Synology guys checked the domain cert but they got it wrong. The cert is valid until 17/Dec/2021. You can easily check it yourself https://www.digicert.com/help/
Luke 42243 Posted August 14, 2021 Posted August 14, 2021 18 hours ago, mcb276084423 said: Already, the problem is found because the NAS's hosts analysis file has a message of 119.28.51.30 mb3admin.com, so no matter what method I use, it will point to this IP. Can you remove that hosts file entry?
