Shortfred 0 Posted February 11, 2021 Share Posted February 11, 2021 Hello, I am lost. Have emby running as docker in unraid and use swag (ngix) as reverse proxy. Is externally also reachable all good. Internally also reachable under localIp:8096. however, it looks like I am logged in remotely although I access internally. Problem with this is: 1. the users are no longer displayed to log in 2. I can not log in as admin because he is not allowed to do that from remote. What can be the reason for this and what can i do. Link to comment Share on other sites More sharing options...
Shortfred 0 Posted February 11, 2021 Author Share Posted February 11, 2021 Ok solved Link to comment Share on other sites More sharing options...
Luke 37332 Posted February 11, 2021 Share Posted February 11, 2021 Hi, what was the solution? Link to comment Share on other sites More sharing options...
Solution Shortfred 0 Posted February 12, 2021 Author Solution Share Posted February 12, 2021 Hi Luke thank you for your message. I have to switch the Network to Host mode in Unraid Docker container. Then i can access to to the Admin account. After that i have to go to Embysettings -> network -> and put my local Ip to "Local Networks" (in my case 10.10.8.0/24). After that i go back in the emby docker settings and switch to "custom: Proxynet" Network again and now all works fine. Link to comment Share on other sites More sharing options...
Luke 37332 Posted February 12, 2021 Share Posted February 12, 2021 Thanks for the feedback. Link to comment Share on other sites More sharing options...
