noope 0 Posted June 19, 2020 Share Posted June 19, 2020 At the moment we have two network types to configure: Local Network + specified through configurable network addresses for ex. 192.168.0.0/24 + Possibility to set user login without password + no bandwidth limits Remote Network (all other networks) + set a bandwidth limit per user or/and per stream I have a VPN connection with a trusted network. I want to set the bandwidth limit for that network and I want to configure login without password. My suggestion: A second network configuration for "trusted external networks" where the user can login without password but the configured bandwidth limits for remote connections are used. additional network: "Trusted external Network": + specified through configurable network addresses for ex. 192.168.10.0/24 - users which are configured to login without password in the local network, can login from this network without password too. - the bandwidth limit is used for this network because its trusted but connected remote (with a vpn for example) Would nice to add this feature and I think its not very difficult to implement it because its possible to use the existing functions. Link to comment Share on other sites More sharing options...
Luke 37132 Posted June 19, 2020 Share Posted June 19, 2020 Hi, yes it's not a bad idea. Thanks for the feedback. Link to comment Share on other sites More sharing options...
