Kmark40 3 Posted June 27, 2014 Share Posted June 27, 2014 Apologies in advance for this question. I've used the search function on the forums, but have been unable to find an answer. I have recently had need to move my media library from the multiple HDDs that it was spread over to two new HDDs. It was from these locations that my UNC shares (for MB3 server) were situated. I now intend to again create UNC shares with the same media library (with exactly the same media with artwork/metadata within their media folders) on these new HDDs. My sever will remain in the same location and so will the all of the associated metadata. My question is, will Mediabrowser server still be able to associate the metadata saved within the server folders with the corresponding media in the UNC shares? Just to clarify, I'm moving all of my media to two new HDDs and want to do so as seamlessly as possible. Thanks Kirk Link to comment Share on other sites More sharing options...
swhitmore 781 Posted June 27, 2014 Share Posted June 27, 2014 I don't see why not. Are the UNC addresses still the same for all folders? 1 Link to comment Share on other sites More sharing options...
Kmark40 3 Posted June 27, 2014 Author Share Posted June 27, 2014 (edited) Thanks for the reply. I did intend to rename the folders and consolidate them into few folders. For example This would all be consolidated into \\Ht-pc\movies 1 \\Ht-pc\movies 2 although the actual physical locations will be on two new HHDs Edited June 27, 2014 by Kmark40 Link to comment Share on other sites More sharing options...
Solution Redshirt 1487 Posted June 27, 2014 Solution Share Posted June 27, 2014 Movies and TV Shows are stored in the DB's using their various ID's (TMDB, TVDB, etc) rather than by physical location. As a result you can move stuff around and your resume states and all that good stuff will be preserved. 1 Link to comment Share on other sites More sharing options...
Kmark40 3 Posted July 3, 2014 Author Share Posted July 3, 2014 All done. Nil issues that I've encountered so far. After migrating and backing up 6 TB of data, everything has re-situated itself in terms of watched, favourites, resume, customizations etc. Thanks for the help :-D 1 Link to comment Share on other sites More sharing options...
