PrincessClevage 175 Posted June 13, 2019 Posted June 13, 2019 (edited) Have there been a recent change to ET ? I seem to have trouble playing live tv, just get a spinning wheel and ET then locks up. I have tested live tv from IOS device and play normally. Even resuming some media hangs Edited June 13, 2019 by PrincessClevage
Guest asrequested Posted June 13, 2019 Posted June 13, 2019 Have you replaced mpv? You can't use an mpv git build later than March 10th.
PrincessClevage 175 Posted June 13, 2019 Author Posted June 13, 2019 Possibly but this issue has only arisen in the last day or so
PrincessClevage 175 Posted June 14, 2019 Author Posted June 14, 2019 What might cause ET to stop being able to play live tv and resume media, I also tested with edge and it can not play youtube either but on the same pc using a different profile login edge works fine. Any ideas ?
Guest asrequested Posted June 14, 2019 Posted June 14, 2019 I'm not sure that those two things are related. As for Theater, try a clean installation of your GPU driver.
