Auto Organizing Not Finding Metadata on TV Show
When I attempt to manually enter in the details of a show, auto-organize will pop up with "Error: null" as seen in this screenshot.
Here is an error report I found in the log.
emby.txt
Edited by miguy973
Hello @@miguy973
Can you attach the screenshot? Thanks.
Best
- James
Hello,
it works again. I renamed the repertore or stored my files, and recreated another blank. And I moved all the folders in the directory tracked by auto organize, and miracle it works again
Hello @@miguy973
Thanks for the update, if you have any other issues don't hesitate to get in touch.
Best
- James
