parrymruk 11 Posted January 23, 2019 Share Posted January 23, 2019 Hi, I recently updated to 4.0.1 and since then my Kodi apps are forcing a login box every time kodi restarts. Is there a way of forcing the creds to cache or is this a bug? I saw an earlier post in regards to this on 4.0.0.2 but it was supposedly fixed in the latest release? Thanks in advance. M Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted January 23, 2019 Share Posted January 23, 2019 Just out of curiosity, you couldn’t search the kodi subsection for an answer? There’s like 10+ posts about this issue... Only the beta version of Emby for Kodi is supported with server 4.0. I should have a new stable out I hope today. That will fix the login situation, that is caused by breaking changes that happened between server 3.5 and now. 1 Link to comment Share on other sites More sharing options...
