JackTramiel 0 Posted January 19, 2019 Posted January 19, 2019 (edited) Server: WHS2011 running Emby 4.0.2 Clients: x86 LibreElec 8.95.2 (clean installation some days ago.) , RPI3 LibeElec 8.95.2, Khadas VIM LibreElec, all Clients do not work correctly Emby for Kodi 3.1.44a ( AddOn Mode ) Hi, since some days i have a problem with media playback. Today, a movie startet. I stopped it and started the movie again but from then there was no more media playback possible. Right now my living room htpc is not starting any media. Except i start remote playback from embys webinterface. Dont know if this belongs together, but i had issues with live tv with my iOS device, too. Basicly the same behavior, only that movies and tv series were running fine. I can provide more detailed logs later. log-2019-01-19-15.29.38.zip Edited January 19, 2019 by JackTramiel
Angelblue05 4131 Posted January 19, 2019 Posted January 19, 2019 Thanks for providing your log, I'm not sure yet what the issue is, I see some errors like your user is not authenticated, but it clearly is in your log. I'll update you once I find out more. 1
Solution Angelblue05 4131 Posted January 20, 2019 Solution Posted January 20, 2019 Install. 3.1.45. Repair your libraries. Your issue should be resolved. 1
JackTramiel 0 Posted January 20, 2019 Author Posted January 20, 2019 That is what i would call a fast solution. Thanks a lot. Resync is running.
