ShoutingMan 95 Posted November 25, 2018 Share Posted November 25, 2018 I noticed that the library Filter function doesn’t seem to work. Almost everything, HD and 4K, is incorrectly tagged as SD. Is this user error on my part, or is this a known Emby limitation? Am I supposed to manually set the video type of my content? Thanks. Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 25, 2018 Share Posted November 25, 2018 Hi try refreshing metadata on some of your titles and then see if they filter correctly. Thanks. Link to comment Share on other sites More sharing options...
ShoutingMan 95 Posted November 26, 2018 Author Share Posted November 26, 2018 (edited) Hi try refreshing metadata on some of your titles and then see if they filter correctly. Thanks. Thanks. That fixed 99% of it. I refreshed metadata at the library level and that updated almost everything. The few quirks are two 4K titles that are flagged as HD. It might be because I have both HD and UHD files for the movie in the same folder (using the multiple version filenaming). A couple of other movies done that way get flagged as 4K, and a couple get flagged as HD. That's not a big deal. (Eventually, I hope to upgrade to 4K and remove the duplicate HD files.) Edited November 26, 2018 by ShoutingMan Link to comment Share on other sites More sharing options...
Luke 37064 Posted November 26, 2018 Share Posted November 26, 2018 Thanks for the feedback. Link to comment Share on other sites More sharing options...
