sse450 2 Posted April 17, 2018 Share Posted April 17, 2018 I relocated my Emby server to another linux box. Now, I used the same setup from the Emby backup but just changed TV and Movie folder paths. Following a new library scan, now, I see all the episodes and movies double in Kodi. One of the double entries is working, the other is not. What is the best course of action to correct this? Thanks for the support. Link to comment Share on other sites More sharing options...
Solution Angelblue05 4130 Posted April 17, 2018 Solution Share Posted April 17, 2018 Run a manual sync, it should remove what doesn't exist anymore. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
sse450 2 Posted April 18, 2018 Author Share Posted April 18, 2018 Worked perfectly. Thank you. 1 Link to comment Share on other sites More sharing options...
