Guest asrequested Posted May 10, 2018 Share Posted May 10, 2018 I'm glad you guys are looking into this, the last release playback quality leaves a lot to be desired. It sounds like you're looking at the right areas. I'm not sure if I can help with testing, it sounds like you have it figured out at this point. But if you need another PC perspective let me know and I'll try to help. I have two Intel i7 desktops with nVidia GTX770 and GTX970, as well as an i3 laptop with integrated graphics. It would be great to see these fixes integrated into a released version someday. Actually, I'd like to see how this works with an Nvidia GPU. Can you try it? vf=d3d11vpp=deint=yes:interlaced-only=yes:mode=adaptive Link to comment Share on other sites More sharing options...
lifespeed 42 Posted May 10, 2018 Author Share Posted May 10, 2018 (edited) Actually, I'd like to see how this works with an Nvidia GPU. Can you try it? vf=d3d11vpp=deint=yes:interlaced-only=yes:mode=adaptive Yes, tonight. In Emby Theatre de-interlace = off, acceleration = CUDA? Edited May 10, 2018 by lifespeed Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 10, 2018 Share Posted May 10, 2018 Deinterlace off, and try both CUDA and D3D. Auto HWA should always set D3D. Link to comment Share on other sites More sharing options...
lifespeed 42 Posted May 11, 2018 Author Share Posted May 11, 2018 Actually, I'd like to see how this works with an Nvidia GPU. Can you try it? vf=d3d11vpp=deint=yes:interlaced-only=yes:mode=adaptive It works great! Smooth on both progressive content and 1080i Live TV. GPU usage is lowest at 22% with CUDA copyback, highest at 60% with AUTO or AUTO copyback. This is with an i7-6800K and GTX-770. Will try the other PC shortly. Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 11, 2018 Share Posted May 11, 2018 And it deinterlaced correctly, when set to CUDA? I was expecting that to not work. Although, you used Cuda-copyback, so that may be allowing the use of other filters. Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 11, 2018 Share Posted May 11, 2018 And you did remove the other deinterlace config from the mpv.conf? Link to comment Share on other sites More sharing options...
lifespeed 42 Posted May 11, 2018 Author Share Posted May 11, 2018 And it deinterlaced correctly, when set to CUDA? I was expecting that to not work. Although, you used Cuda-copyback, so that may be allowing the use of other filters. Yes, it de-interlaced in all configurations. CUDA, CUDA copyback, AUTO, AUTO copyback. And you did remove the other deinterlace config from the mpv.conf? This is my mpv.conf file: log-file=C:\Users\User1\AppData\Roaming\mpv\Theater mpv log.txt vf=d3d11vpp=deint=yes:interlaced-only=yes:mode=adaptive Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 11, 2018 Share Posted May 11, 2018 That's great! Glad to see it works, well. Link to comment Share on other sites More sharing options...
Luke 37112 Posted May 11, 2018 Share Posted May 11, 2018 Would it be better to open a ticket with mpv to suggest this as default behavior? Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 11, 2018 Share Posted May 11, 2018 Would it be better to open a ticket with mpv to suggest this as default behavior? It used to be. They've only just made this change. The release version still has the original, but you've used shinciro's build, which has the new changes. I posted the change, in mpv testing thread. https://emby.media/community/index.php?/topic/46763-theater-mpv-test/?p=551023 I don't think they'll just switch it back. Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 27, 2018 Share Posted May 27, 2018 @@lifespeed Heads up. Using that deinterlacing I gave you, if you watch HDR 10, it will be converted to 8 bit. Link to comment Share on other sites More sharing options...
lifespeed 42 Posted May 27, 2018 Author Share Posted May 27, 2018 @@lifespeed Heads up. Using that deinterlacing I gave you, if you watch HDR 10, it will be converted to 8 bit. It won't affect me personally as I don't yet have HDR, but does mean more work is needed to get this all straightened out. Link to comment Share on other sites More sharing options...
Guest asrequested Posted May 27, 2018 Share Posted May 27, 2018 (edited) It won't affect me personally as I don't yet have HDR, but does mean more work is needed to get this all straightened out. This is an mpv, issue. I have reported it https://github.com/mpv-player/mpv/issues/5861 But I think it's going to be ignored. Edited May 27, 2018 by Doofus Link to comment Share on other sites More sharing options...
