skuzzzzy 0 Posted March 2, 2014 Share Posted March 2, 2014 is auto mount for iso's broken? my mediabrowser will not auto mount. ive tried with daemon tools lite and dvdfab. only way i can watch iso files is by manually mounting. Link to comment Share on other sites More sharing options...
Solution dkindig 1 Posted March 3, 2014 Solution Share Posted March 3, 2014 I am using Virtual Clone Drive with a path of C:\Program Files\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe. My other options are of course, correct drive letter, and I had to check "Use Autoplay" to get mine to mount. You might try playing with the autoplay setting and double-checking that drive letter is correct. Other than that, maybe give Virtual Clone Drive a shot? Hope this helps... 1 Link to comment Share on other sites More sharing options...
skuzzzzy 0 Posted March 3, 2014 Author Share Posted March 3, 2014 (edited) I am using Virtual Clone Drive with a path of C:\Program Files\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe. My other options are of course, correct drive letter, and I had to check "Use Autoplay" to get mine to mount. You might try playing with the autoplay setting and double-checking that drive letter is correct. Other than that, maybe give Virtual Clone Drive a shot? Hope this helps... virtual drive clone is now paid ware i believe =\. nvm i got that and clonedvd mixed up. i will try that tonight thanks! Edited March 3, 2014 by skuzzzzy Link to comment Share on other sites More sharing options...
skuzzzzy 0 Posted March 4, 2014 Author Share Posted March 4, 2014 ok so now it works perfect but.. it wont full screen. any ideas? using totalmedia6 Link to comment Share on other sites More sharing options...
Xzener 729 Posted March 4, 2014 Share Posted March 4, 2014 What resolution is your HTPC set to?? Link to comment Share on other sites More sharing options...
skuzzzzy 0 Posted March 4, 2014 Author Share Posted March 4, 2014 What resolution is your HTPC set to?? 1080p, the border only happens when totalmed opens threw wmc Link to comment Share on other sites More sharing options...
skuzzzzy 0 Posted March 6, 2014 Author Share Posted March 6, 2014 fixed border isue by switching "TV" to "Monitor" on windows media settings Link to comment Share on other sites More sharing options...
