Live TV special characters in recordings
saitoh183
Is this a issue with the plugin or MBS? I just added Live TV with WMCServer plugin and french shows that contain accent letter in the description or title appear like "??".
krustyreturns
I'm pretty sure that's on serverwmc.  Can you post the original file name so that I can see where its happening?
saitoh183
Unité 9_CBFTDT_2014_02_25_19_58_00.wtv
it also happens in TV guide
Edited by saitoh183
krustyreturns
OK, I'll let you know what I find.
It is Cyrillic ((
krustyreturns
Bug fix is up.  Look for version 1.0.0.26 of the plugin.
saitoh183
Works like a charm, Thank you for the quick fix
Yesss!  :)
