Rotten Tomatoes questions
Go to solution Solved by marcelveldt,
1. Does Kodi read the rotten tomatoes metadata in Emby or does it pull that info directly using its own add-ons? (For consistency sake, I think the info should come from Emby since it's already stored there)
2. Can anyone suggest a good Kodi skin with Rotten Tomatoes support? I can't seem to find one that is as elegant as the Emby built-in one (as seen in web browser).
  • Solution
marcelveldt
Rotten tomatoes info is no longer provided as they started charging a hell lot of money for the API usage
Verzonden vanaf mijn iPhone met Tapatalk
  • Like 1
wow, this sounds sad. But are you referring to Kodi only?
On the browser version of Emby, I still see Rotten Tomatoes scores.
  • 2 weeks later...
marcelveldt
I'm indeed referring to Kodi but the same applies to Emby itself as that will most likely also start to fail soon
This is really too bad. Maybe there will be alternatives soon.
Angelblue05
Trakt rating?
Guest
