Play to MBC doesn't appear to work
Logos302
 Share
Logos302
When trying to use the play to function to play to MBC nothing happens.  I'm not sure what logs you need, I'm assuming that you need the app logs (Which once I'm at home I'll send).  As a side note doing the same thing from the web client on my laptop sending to MBC works as it should.
Link to comment
Share on other sites
Redshirt
You'll need to supply all three logs. The app log, the server log and an MBC log. They all play a part in the process.
Link to comment
 Share
