inesergio 11 Posted October 5, 2016 Share Posted October 5, 2016 when using latest beta of emby addon with kodi 17 beta 3 the episodes shows in incorrect order. tried with different skins. Not all shows just some it shows epsidode 1, episode 2, epsiode 6, epsiode 3.... I know that kodi 17 is not supported but it's a addon bug or some setting in the server that I changed by mistake? Link to comment Share on other sites More sharing options...
Solution Angelblue05 4130 Posted October 5, 2016 Solution Share Posted October 5, 2016 (edited) Is this an issue with new episodes? (It shouldn't be) Check this server thread about to resolve this: https://emby.media/community/index.php?/topic/38003-kodi-nfo-problem Edited October 5, 2016 by Angelblue05 Link to comment Share on other sites More sharing options...
inesergio 11 Posted October 5, 2016 Author Share Posted October 5, 2016 the symptoms are the same but I don't use nfo's. will check Link to comment Share on other sites More sharing options...
Angelblue05 4130 Posted October 5, 2016 Share Posted October 5, 2016 Keep me posted. The only thing that effects the episode ordering in kodi is the episode number and airsbefore/after. If the episode number is correct, then you know what the issue is. The wrong information must still exist in your Emby database even if you don't use nfos and that's what the addon is adding to your Kodi database. Link to comment Share on other sites More sharing options...
inesergio 11 Posted October 5, 2016 Author Share Posted October 5, 2016 I deleted the offending line in all emby created nfos and will let the tvshows refresh run over night. will keep you posted. thank you 1 Link to comment Share on other sites More sharing options...
inesergio 11 Posted October 6, 2016 Author Share Posted October 6, 2016 I haven't checked all shows but the ones I checked problem solved. Thank you very much 1 Link to comment Share on other sites More sharing options...
