ROC coverflow issue
c0m3r
 Share
Go to solution Solved by leedavies,
I've been trying out various themes and have settled on ROC for the moment. For the past few days however am having a strange issue with coverflow. Everything is fine except for the cover for the movie/tv show etc. will appear to be very poor resolution when it is highlighted. It starts off fine however as the highlighted cover enlarges, it seems to lose focus as though the image is of poor resolution. In all other views however it appears to be in perfect resolution and works fine with all other themes. Any idea on the cause? Thanks
Link to comment
Share on other sites
  • Solution
Yes, this issue was reported very recently and there is a patch release on the way.
One of the recent optimizations to squeeze a little more performance out of scrolling was a little aggressive and left the currently highlighted item showing a low-res version of the coverart.
There will be a fix release within the next couple of days.
  • Like 1
Link to comment
 Share
