doug.dimick 12 Posted April 10, 2016 Share Posted April 10, 2016 Crossposting from Premier Support as I'm not sure where it belongs. This is a previously working Emby Premier install. I'm not certain when it broke, but currently: 2016-04-09 12:22:20.9293 Info HttpClient: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate 2016-04-09 12:22:20.9456 Error SecurityManager: Error checking registration status of MBSupporter *** Error Report *** Version: 3.0.5911.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.2 (Stable 4.2.2.10/7b87787 Tue Apr 5 01:43:49 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Type definitions should start with a '{', expecting serialized type 'RegRecord', got string starting with: GIF89a ? ? !? , ; System.Runtime.Serialization.SerializationException at ServiceStack.Text.Common.DeserializeTypeRefJson.StringToType (ServiceStack.Text.TypeConfig typeConfig, System.String strType, ServiceStack.EmptyCtorDelegate ctorFn, System.Collections.Generic.Dictionary`2 typeAccessorMap) <0x2d5820 + 0x010d9> in <filename unknown>:0 at ServiceStack.Text.Common.DeserializeType`1+<>c__DisplayClass3[TSerializer].<GetParseMethod>b__1 (System.String value) <0x2d5760 + 0x00035> in <filename unknown>:0 at ServiceStack.Text.Json.JsonReader`1[T].Parse (System.String value) <0x2b5e90 + 0x0026c> in <filename unknown>:0 at ServiceStack.Text.JsonSerializer.DeserializeFromString[T] (System.String value) <0x2b5160 + 0x00081> in <filename unknown>:0 at ServiceStack.Text.JsonSerializer.DeserializeFromStream[T] (System.IO.Stream stream) <0x2b49e0 + 0x0009f> in <filename unknown>:0 at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromStream[T] (System.IO.Stream stream) <0x2b4920 + 0x00042> in <filename unknown>:0 at MediaBrowser.Common.Implementations.Security.PluginSecurityManager+<GetRegistrationStatusInternal>c__async2.MoveNext () <0x898620 + 0x00906> in <filename unknown>:0 Link to comment Share on other sites More sharing options...
Solution doug.dimick 12 Posted April 11, 2016 Author Solution Share Posted April 11, 2016 Resolved, issue was due to an overactive DNS blacklist filter on pfBlockerNG, nothing to do with Emby. 1 Link to comment Share on other sites More sharing options...
