Luke 37176 Posted January 16, 2016 Share Posted January 16, 2016 Yea a fix won't come with a server update but rather a plugin update. Link to comment Share on other sites More sharing options...
gebhard 3 Posted January 26, 2016 Author Share Posted January 26, 2016 Hi, I've updated Emby to version 3.0.5786.0 and the Podcast plugin to 1.0.5863.23594 but the error is still there: 2016-01-26 19:16:54.3601 Error App: Error getting channel content *** Error Report *** Version: 3.0.5786.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe String was not recognized as a valid DateTime. System.FormatException Cheers Gebhard Link to comment Share on other sites More sharing options...
Luke 37176 Posted January 26, 2016 Share Posted January 26, 2016 @@gebhard I've posted an update to the plugin. It's marked as a beta so you'll need to set your update level as Beta in order to see it. (Under advanced). Please try it out and report back. Thanks. Link to comment Share on other sites More sharing options...
gebhard 3 Posted January 27, 2016 Author Share Posted January 27, 2016 Hi, sorry for the stupid question ... but I can't find an FAQ entry about enabling beta content. I've set the update to beta in the advanced tab (see screenshot ) but I'm still offered only release versions (screenshot ). Emby restart doesn't seem to change anything. Sorry for the n00b question, but I don't get it. Thanks, Gebhard Link to comment Share on other sites More sharing options...
Luke 37176 Posted January 27, 2016 Share Posted January 27, 2016 It's depending on server version 3.0.5818. I will lower that. That could be it, if you're not running the latest version of the server. Try restarting emby server. Link to comment Share on other sites More sharing options...
gebhard 3 Posted January 28, 2016 Author Share Posted January 28, 2016 Hi, I'm sorry, but as of now I can't see any difference, I'm still offered only release versions of the plugin ... Anything else I could be missing here? Thanks, Gebhard Link to comment Share on other sites More sharing options...
Luke 37176 Posted January 28, 2016 Share Posted January 28, 2016 what is your server version? Link to comment Share on other sites More sharing options...
gebhard 3 Posted January 28, 2016 Author Share Posted January 28, 2016 It's version 3.0.5786.0 (latest version for FreeNAS). Link to comment Share on other sites More sharing options...
Luke 37176 Posted January 28, 2016 Share Posted January 28, 2016 Ok, I've changed the plugin to work with that version. You should be able to see it now, although there is some caching so you might need to restart emby server in order to see it immediately Link to comment Share on other sites More sharing options...
gebhard 3 Posted January 28, 2016 Author Share Posted January 28, 2016 Hi, thanks, I'm now on Emby version 3.0.5786.0 and Podcast plugin version 1.0.5870.21844. Sadly it's not yet working: 2016-01-28 16:33:49.4233 Error App: Error getting channel content *** Error Report *** Version: 3.0.5786.0 Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 9.1.0.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.1 (Stable 4.2.1.124/39edf24 Sun Jan 10 05:27:13 UTC 2016) Application Path: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe String was not recognized as a valid DateTime. System.FormatException at System.DateTimeParse.ParseExactMultiple (System.String s, System.String[] formats, System.Globalization.DateTimeFormatInfo dtfi, DateTimeStyles style, System.TimeSpan& offset) <0x813489280 + 0x00124> in <filename unknown>:0 at System.DateTimeOffset.ParseExact (System.String input, System.String[] formats, IFormatProvider formatProvider, DateTimeStyles styles) <0x813488cc0 + 0x00081> in <filename unknown>:0 at System.Xml.XmlConvert.ToDateTimeOffset (System.String s, System.String[] formats) <0x813488c00 + 0x0004d> in <filename unknown>:0 Thanks, Gebhard Link to comment Share on other sites More sharing options...
Luke 37176 Posted January 28, 2016 Share Posted January 28, 2016 That's really odd because that looks like an error message from the previous version. Did you restart the server after updating the plugin? I will push another plugin update just in case it makes a difference. Thanks. Link to comment Share on other sites More sharing options...
gebhard 3 Posted January 28, 2016 Author Share Posted January 28, 2016 Yes, I did restart ... interestingly the error doesn't appear in the notification sections in the web interface but only in the log file ... but no podcast appears nevertheless. I'll try the new beta version ASAP. Cheers, Gebhard Link to comment Share on other sites More sharing options...
Luke 37176 Posted January 28, 2016 Share Posted January 28, 2016 I've pushed an update, I did actually find one more change that was needed to be made, sorry. Link to comment Share on other sites More sharing options...
Solution gebhard 3 Posted January 28, 2016 Author Solution Share Posted January 28, 2016 Thanks, this one actually worked: I can now see the configured podcasts in the respective lib and can play them :-) Great work, thanks for being patient. Nevertheless the channel downloader doesn't work (doesn't display any channel, but only the spinning wheel), bus this is stuff for another thread I think ... Cheers, Gebhard 1 Link to comment Share on other sites More sharing options...
Luke 37176 Posted September 11, 2016 Share Posted September 11, 2016 The Podcasts plugin has been updated with a new configuration screen to match the look and feel of the rest of Emby Server. I think you'll find it much more enjoyable to use and configure now. Thanks. Link to comment Share on other sites More sharing options...
gebhard 3 Posted September 22, 2016 Author Share Posted September 22, 2016 Hi, thanks for the notice. I'll have a look and provide feedback when the server and plugins are on the latest release in freenas. Cheers, Gebhard Link to comment Share on other sites More sharing options...
tomimc 13 Posted March 15, 2017 Share Posted March 15, 2017 (edited) sorry :/ i post in wrong post Edited March 15, 2017 by tomimc Link to comment Share on other sites More sharing options...
