whorainy 0 Posted August 5, 2015 Share Posted August 5, 2015 Sorry if this has been answered previously, but i didn't find much via a search. There's a spot to configure or upload a trusted server certificate for the external HTTPS host but i don't see a place to generate a signing request to take to a third party. Do you just do this using openSSL or something, or does the emby server have a tool to generate the key? Thanks in advance. Link to comment Share on other sites More sharing options...
Solution Lumute 90 Posted August 5, 2015 Solution Share Posted August 5, 2015 (edited) You can do it with many different servers like IIS, check this out: https://www.instantssl.com/ssl-certificate-support/csr-generation/ssl-certificate-index.html You can install IIS on a windows 7+ and use it to generate your CSR and when all its done export the certificate. If you go with StartCom's free certificate then they'll generate one for you and provide you the private key. If you prefer to pay for a more reputable certificate, check GoGetSSL, they have good prices and also an online tool to generate the CSR: https://www.gogetssl.com/ Edited August 5, 2015 by Lumute 1 Link to comment Share on other sites More sharing options...
whorainy 0 Posted August 6, 2015 Author Share Posted August 6, 2015 Cool Thanks. That's what I figured was to use something like openssl or IIS. Appreciate the response. Link to comment Share on other sites More sharing options...
