I am having a strange issue when trying to use random intros.
Windows version: 8.1 x64
Both standard Cinema Mode and Advanced Intros exhibits the following behaviour:
Works perfectly for random trailers from local library.
Works perfectly for specific intro file.
Does not work when asking it to get a random file from a directory, this goes for audio intros and random trailers.
So basically any time you just put in a directory, not a specific file, it will not work. Says null item.
  • 3 weeks later...
hey Arsim, if you choose a new path for the custom intro, you have to run a new media scan - now it should be there.
