Screenshot Grabber
Maleficarum
 Share
Maleficarum
What does it do?
Screenshot grabber allows you to specify a video file and will dump images from the video based on the number of images you set and the frequency you choose.
How do I do it?
  • Press the "Select file" button and choose the video you want to use.
  • Press the "Choose folder" button and choose the folder where you want the images to be saved.
  • Select how many images you want to save.
  • Choose how often you want images to be saved.
  • Press start
  • Profit
Can I stop before it reaches the end of the video?
Yes just hit the stop button or close the app at any time.
download-button.png?psid=1
  • Like 2
Link to comment
Share on other sites
Smaky
Thanks for this tool. It works really well. Only issue I´ve found so far is that whenever you close the tool it crahes.
Link to comment
Maleficarum
When did you download it ? If it was shortly after it's initial posting then there was a bug which was fixed fairly soon afterwards.
Edited by Maleficarum
Link to comment
Smaky
Well... I just downloaded it yesterday.
Was wondering about a feature request:
Have the app process all MKVs within a specified folder. That will be very helpful to extract snapshots from TV series by avoiding to have to manually select each file individually.
Link to comment
Maleficarum
Hmm well the latest version I have doesn't do it so I don't know what to tell you unless the upload didn't work correctly I will upload again and see what happens.
As for the feature request I can see what I can do, it was never intended to be a batch process as the server does that already but I'll look into what can be done.
Link to comment
  • 2 months later...
 Share
