bluc 21 Posted February 6, 2015 Share Posted February 6, 2015 (edited) Hey all I have issues with constant buffering with the kodi mb3 client. I have media browser server setup to access unc shares all shares are available on all my pcs direct via the network browser in windows and all files play fine without any buffering issues. When I go into kodi which I have setup in media browser mode the media browser server wants to trans-code files and I get buffering every few seconds. My network is gigabit wired between pcs I get around 85MB/s but to the media browser server which runs on a nuc I get around 30MB because its limited by usb 2 (media on external drive). So trying to work out if I Have a setting wrong in the client or on the server,all my files should be able to be played on pcs without the need for trans-coding correct? On a side note the android app over wireless works flawless no buffering at all on my phone and tablet over wireless ac. The nuc is the original i3 has 4GB ram. Programs on a msata drive media on an external usb drive. Edited February 6, 2015 by bluc Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 Have just setup the media browser windows 8 app and the buffering issue is not present so perhaps a kodi issue? Any ideas of a fix? Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 6, 2015 Share Posted February 6, 2015 Is it possible for you to post a log? http://mediabrowser.tv/community/index.php?/topic/17599-how-to-report-a-problem/ I'm wondering if maybe the files are transcoding for some reason. The log should give us a clue. Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 Heres a log http://xbmclogs.com/show.php?id=416419 I set the log level to info then restarted kodi and started playing an example video that transcodes instead of direct play I also tried adding "mkv" to my "dnla generic direct play profile" made no difference. Even tried adding a new dnla profile no luck Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 6, 2015 Share Posted February 6, 2015 It is transcoding, because of the path added in Media Browser like null_pointer said. You said you already set up UNC paths in your media browser. Does it look like this? http://mediabrowser.tv/community/index.php?/topic/703-how-to-make-unc-folder-shares/ Thanks for verifying. Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 15:57:39 T:6984 NOTICE: Checking existence of : G:\music movies\temp music movies\The Australian Pink Floyd Show Eclipsed By The Moon 2013\The Australian Pink Floyd Show Eclipsed By The Moon 2013.mkv 15:57:39 T:6984 NOTICE: Path does not exists You need to use UNC paths when you set up Media Browser libraries or path substitution. Oh ok I thought that was for content on different pc then server. Re setting up library will see how it behaves once finished. Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 (edited) Cool ok as soon as the library builds will try again and post back. Edited February 6, 2015 by bluc Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 (edited) Still trans coding here's a second log http://xbmclogs.com/show.php?id=416477 Looking at the log I still havent got my shares right will be back later after I reset up from scratch. Edited February 6, 2015 by bluc Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 Library is building again Got to ask whats the difference between sharing like this guide http://mediabrowser.tv/community/index.php?/topic/703-how-to-make-unc-folder-shares/ and just right clicking the folder/share with specific people/ add the media browser server account as owner then add everyone as read then click share? Link to comment Share on other sites More sharing options...
bluc 21 Posted February 6, 2015 Author Share Posted February 6, 2015 Ok so now its trying to play direct but everything except live tv/recordered tv is failing to play here's another log http://xbmclogs.com/show.php?id=417163 Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 7, 2015 Share Posted February 7, 2015 How did you set up your live TV? Is it similar to what is said here? http://mediabrowser.tv/community/index.php?/topic/17663-live-tv/ Link to comment Share on other sites More sharing options...
bluc 21 Posted February 7, 2015 Author Share Posted February 7, 2015 In kodi I just use the kodi dvblink pvr add on, for the media browser apps and server I use the dvblink add on for media browser which works fine via the media browser apps windows/android. Just cant get the xbmc media browser add on to play nice at all. Only thing I have working is tv but that comes via the kodi add on not media browser. Link to comment Share on other sites More sharing options...
fuzzthekingoftrees 10 Posted February 12, 2015 Share Posted February 12, 2015 Be careful with your logs, these ones have your windows username/password in which is also your hotmail username/password. You should probably pull these and upload some obfuscated ones, just do a find replace for your username/password. With that said, if your network is windows->windows, you shouldn't need to enter a username and password in kodi for the smb shares, I know I don't on my network. Just set up a homegroup and have all your computers join. The other option is to use http streaming but set your maximum bitrate correctly in the xbmb3c plugin. On your LAN you can set it to 100Mbps then any files below this rate (which should be everything) will direct stream over http. Link to comment Share on other sites More sharing options...
bluc 21 Posted February 13, 2015 Author Share Posted February 13, 2015 Thanks for the heads up about the log will go change my hotmail pasword cheers Link to comment Share on other sites More sharing options...
bluc 21 Posted February 16, 2015 Author Share Posted February 16, 2015 (edited) Found the issue with playback failing with error "MSGQ_NOT_INITIALIZED" was a permissions issues still not sure whats going on. Each of my media shares has "everyone" "read" permission and my main server account read write permissions. If I leave the username password blank in the xbmc mb3 addon it plays fine as soon as I add my admin username password it fails. But happy for now it plays direct and no more buffering. Android clients work great will have to look into whats going on with my share's admin permissions.. Edited February 16, 2015 by bluc Link to comment Share on other sites More sharing options...
cpthooker 3 Posted February 17, 2015 Share Posted February 17, 2015 I have been having this trouble and will try what you did to fix it. Link to comment Share on other sites More sharing options...
cpthooker 3 Posted February 21, 2015 Share Posted February 21, 2015 Still has the buffering issue. Any suggestions? Link to comment Share on other sites More sharing options...
Angelblue05 4127 Posted February 21, 2015 Share Posted February 21, 2015 Which mediabrowser addon version are you using? If you are unsure, you can find this information by navigating to the addon splash page in kodi (settings > addons > enabled addons > video addon) Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
bluc 21 Posted February 21, 2015 Author Share Posted February 21, 2015 Still has the buffering issue. Any suggestions? Main reason mine was buffering was because it was transcoding. Make sure your shares are setup correctly as network address's not as local folders in the media browser server. Then it will only transcode when it needs to. I now get no buffering issues anywhere. Link to comment Share on other sites More sharing options...
cpthooker 3 Posted February 22, 2015 Share Posted February 22, 2015 I am using version 0.9.770. I did try to do the suggested folder config but couldn't get it to work. I think I will need to redo my folders better for it to work. Link to comment Share on other sites More sharing options...
Solution Angelblue05 4127 Posted February 22, 2015 Solution Share Posted February 22, 2015 (edited) @@cpthooker You have two choices, path substitution or UNC shares. The following links should help you set up your folder paths correctly. The path substitution one is not a tutorial, but the thread is informative. A - Path substitution http://mediabrowser.tv/community/index.php?/topic/17357-substitution-path-setup/?p=168791 B - UNC Shares http://mediabrowser.tv/community/index.php?/topic/703-how-to-make-unc-folder-shares/ Edited February 22, 2015 by Angelblue05 1 Link to comment Share on other sites More sharing options...
cpthooker 3 Posted March 2, 2015 Share Posted March 2, 2015 Forgot to respond, but it is working now thanks to the unc shares Link to comment Share on other sites More sharing options...
