somy 24 Posted January 7, 2015 Share Posted January 7, 2015 Hi all, When I installed MB3 I was asked to login and enable mediabrowser connect, and I chose skip. Now I'd very much like to enable it, but where can I enable it when the server is already configured? I also have a few questions regarding how it works: 1. Does MB3 configure the router (upnp) to configure port forwarding? It doesn't happen in my case as the URL in the dashboard doesn't seem to work. 2. What exactly does MB connect do? Does it stream media to web and cache them? How does it handle IP address change? Thank you in advance! Link to comment Share on other sites More sharing options...
Solution swhitmore 781 Posted January 7, 2015 Solution Share Posted January 7, 2015 Hey. Please check out this blog post. If you still have questions, I'll follow up for you. http://mediabrowser.tv/community/index.php?/blog/1/entry-130-media-browser-server-305416-beta-released/ 1 Link to comment Share on other sites More sharing options...
somy 24 Posted January 7, 2015 Author Share Posted January 7, 2015 Thanks for the help! It works perfectly! 1 Link to comment Share on other sites More sharing options...
