bnwbass 3 Posted October 29, 2013 Share Posted October 29, 2013 Started my system today and out of the blue I'm now getting "manual login screen when I open the MB dashboard? Anyone know why this is happening? Everything was normal yesterday. I never setup a login or password for MB server so I'm in a loop that I cant gain access. Re-install server MB? thx bw Link to comment Share on other sites More sharing options...
swhitmore 781 Posted October 29, 2013 Share Posted October 29, 2013 What version are you running? Link to comment Share on other sites More sharing options...
bnwbass 3 Posted October 29, 2013 Author Share Posted October 29, 2013 3.0.5031.21343 Link to comment Share on other sites More sharing options...
swhitmore 781 Posted October 29, 2013 Share Posted October 29, 2013 Hmm, I've already updated to the next beta. Is that a dev version? I'm not too sure what you should do now. You might have to re-install, or wait from an answer from one of the devs. Link to comment Share on other sites More sharing options...
DGMayor 88 Posted October 29, 2013 Share Posted October 29, 2013 3.0.5049.22196 is the latest beta. Link to comment Share on other sites More sharing options...
swhitmore 781 Posted October 29, 2013 Share Posted October 29, 2013 3.0.5049.22196 is the latest beta. It's a staggered rollout, so he might not have the notification yet. Although, if he can't get to the dashboard he won't be able to update without reinstalling anyway Link to comment Share on other sites More sharing options...
Luke 37259 Posted October 29, 2013 Share Posted October 29, 2013 try deleting the server config file and restarting the server. you'll then need to re-enter all your settings. if that doesn't work delete the users.db file Link to comment Share on other sites More sharing options...
DGMayor 88 Posted October 29, 2013 Share Posted October 29, 2013 It's a staggered rollout, so he might not have the notification yet. Although, if he can't get to the dashboard he won't be able to update without reinstalling anyway yeah I know - previous is what he's on - 3.0.5031.21343. I just looked at my logs. (mine JUST updated). Link to comment Share on other sites More sharing options...
Solution bnwbass 3 Posted October 29, 2013 Author Solution Share Posted October 29, 2013 try deleting the server config file and restarting the server. you'll then need to re-enter all your settings. if that doesn't work delete the users.db file Thanks, this what I did and all ok now 3.0.5049.22196 installed. Link to comment Share on other sites More sharing options...
