rockmeister 0 Posted November 27, 2014 Share Posted November 27, 2014 Ok. I figured out the issue. I had Chrome as the default browser once I changed it back to IE10, the exception went away. Luke would you consider this a Bug? if so, do you want to put in a Bug Report? Thanks Rockmeister PS: I do have admin privilege on the "tests" account that I used to install MediaBrowser3. Link to comment Share on other sites More sharing options...
Luke 37099 Posted November 27, 2014 Share Posted November 27, 2014 there is no bug here. we tell your system to open the default browser, it gives us an error message. there's nothing we can do to change that. Link to comment Share on other sites More sharing options...
rockmeister 0 Posted November 27, 2014 Author Share Posted November 27, 2014 On a standard Windows 8.1 machine when I install MediaBrowser3 I am getting the following error 2014-11-26 12:33:26.8514 Error - App: Error launching url: http://localhost:8096/mediabrowser/web/wizardstart.html Class not registered System.ComponentModel.Win32Exception at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo) at System.Diagnostics.Process.Start() at MediaBrowser.ServerApplication.Native.BrowserLauncher.OpenUrl(String url, ILogger logger) The entire log is at http://paste2.org/gP3EWa07 I am unable to launch to the configuration wizard... Help greatly appreciated. Thanks Rockmeister Link to comment Share on other sites More sharing options...
Luke 37099 Posted November 27, 2014 Share Posted November 27, 2014 then just open that url in the browser and go from there. that error just means the server can't launch your browser, due to system settings or some other unknown environmental factor. Link to comment Share on other sites More sharing options...
