MikeDarTan 0 Posted March 2 Share Posted March 2 I have a Lifetime Key for Emby but Iconic image Enhancer shows it is not registered. The message is "Unregistered versions of Iconic are limited to one rule match/badge per Movie." Server setup is: Terramaster TOS Version 5.1 Emby Version 4.9.0.5 Iconic Version 2.4.0.0 Thanks for any help on this! Link to comment Share on other sites More sharing options...
vincen 12 Posted March 2 Share Posted March 2 Did you check in Settings of Iconic plugin ? you should find an option to activate it ? (according at thread about it: ) Link to comment Share on other sites More sharing options...
roaku 795 Posted March 2 Share Posted March 2 15 minutes ago, MikeDarTan said: I have a Lifetime Key for Emby but Iconic image Enhancer shows it is not registered. The message is "Unregistered versions of Iconic are limited to one rule match/badge per Movie." Server setup is: Terramaster TOS Version 5.1 Emby Version 4.9.0.5 Iconic Version 2.4.0.0 Thanks for any help on this! Hi. Have you registered Iconic through the catalog? Link to comment Share on other sites More sharing options...
MikeDarTan 0 Posted March 2 Author Share Posted March 2 I do not see an option to "Register" it in the settings menu. Link to comment Share on other sites More sharing options...
roaku 795 Posted March 2 Share Posted March 2 1 hour ago, MikeDarTan said: I do not see an option to "Register" it in the settings menu. From the web app, under the Plugins page, click the Catalog tab: On the Catalog tab, find the General section, and scroll right until you see the Iconic plugin: On the Iconic install page, scroll down until you see the Register button, and if you're feeling generous, click it: Link to comment Share on other sites More sharing options...
vincen 12 Posted March 2 Share Posted March 2 10 minutes ago, roaku said: On the Iconic install page, scroll down until you see the Register button, and if you're feeling generous, click it: Just to be sure once installed you can't register it if you didn't during install right ? Then you have to deinstall and reinstall to get a chance ? Link to comment Share on other sites More sharing options...
roaku 795 Posted March 2 Share Posted March 2 4 minutes ago, vincen said: Just to be sure once installed you can't register it if you didn't during install right ? Then you have to deinstall and reinstall to get a chance ? Just navigate to the button and click it. Link to comment Share on other sites More sharing options...
vincen 12 Posted March 2 Share Posted March 2 52 minutes ago, roaku said: Just navigate to the button and click it. Sorry I was doing it from My Plugins page and not from the catalog page so all good, thanks For info it displays on mine (love precision of expiration time La période d'essai de cette fonction expire dans 14.224809224537037 jour(s) Link to comment Share on other sites More sharing options...
