softworkz 3338 Posted February 22 Share Posted February 22 Damn - same result in both cases, that's the worst possible outcome You've verified that OpenCL is workin in the 4.7 case. Can you confirm that it's non-working in 4.8? Link to comment Share on other sites More sharing options...
MrMackey 26 Posted February 22 Author Share Posted February 22 @softworkz Do you mean that I should just start the LinuxServer Docker container 4.8.1 and try to play the movie again with Hardware Accelerated Tone Mapping? Link to comment Share on other sites More sharing options...
MrMackey 26 Posted February 22 Author Share Posted February 22 In case that's what you meant, here are the logs from 4.8.1embyserver.txtffmpeg-transcode-3da54f77-c5a4-49b9-8b1a-290eb13d065e_1.txtffmpeg-transcode-33bbdccc-751b-4f0f-a975-a00938213bc9_1.txtffmpeg-transcode-e585f9c4-b532-464c-853a-f0dbb2bc632d_1.txthardware_detection-63844238296.txt Link to comment Share on other sites More sharing options...
softworkz 3338 Posted February 22 Share Posted February 22 Yes, that's what I meant. Thanks for the new logs. What raises my suspicion once again is that the 4.7 logs are with downscaling and the 4.8 without. Can you try on 4.7 without downscaling and on 4.8 with downscaling to 1080 - then we'll have an exact comparison. (and when this doesn't reveal anything, the air will start to get thin for me, LOL) Link to comment Share on other sites More sharing options...
MrMackey 26 Posted February 22 Author Share Posted February 22 All right, here is 4.7.14 I have it set to auto. And it has 4k 140Mbps selected. embyserver.txtffmpeg-remux-69e59ea2-d9f7-407f-90f9-d5c670d07990_1.txtffmpeg-remux-4323e8dc-5574-4f3a-8bbb-5773f2ea8f49_1.txtffmpeg-transcode-3fc12313-159e-4b49-9955-6512618a0717_1.txthardware_detection-63844239770.txt And here is 4.8.1 on 1080P 4Mbps embyserver.txtffmpeg-transcode-22688bb7-6eb4-4c64-95ac-1188ef150de1_1.txtffmpeg-transcode-91137d65-15fb-43c9-93af-1053830b62d0_1.txtffmpeg-transcode-361110c2-d2f2-464d-9348-4fdee834034e_1.txthardware_detection-63844240390.txt Link to comment Share on other sites More sharing options...
softworkz 3338 Posted February 22 Share Posted February 22 Thanks again. Now we have the exact same commands, working on one, failing on the other image. The question is about what's different. Let's start with the one that is already prepared and compare the clinfo output from both machines (now you know how to run it). Link to comment Share on other sites More sharing options...
MrMackey 26 Posted February 22 Author Share Posted February 22 (edited) @softworkzDo you want me to run the ./emby-clinfo again on 4.7 and 4.8? In case you meant it, here are the logs. 4.7.14_clinfo.txt4.8.1_clinfo.txt Edited February 22 by MrMackey addes clinfo logs Link to comment Share on other sites More sharing options...
softworkz 3338 Posted February 22 Share Posted February 22 Thanks. The most interesting difference between the two outputs is the ICD loader section at the bottom, which isn't shown in case of the 4.7 image: @alucryd- was there any change regarding the ICD between 4.7 and 4.8 ? Link to comment Share on other sites More sharing options...
alucryd 216 Posted February 23 Share Posted February 23 @softworkzOf course, 4.8 has had a much more up to date OCL stack for a while. Link to comment Share on other sites More sharing options...
softworkz 3338 Posted February 25 Share Posted February 25 On 2/23/2024 at 11:34 AM, alucryd said: @softworkzOf course, 4.8 has had a much more up to date OCL stack for a while. @alucrydOCL-stack, okay, but what about the ICD loader? Why does it show an ICD loader for 4.8 but not with the 4.7 package? Did we do direct linking before? Or do you have any other idea why it doesn't work? Link to comment Share on other sites More sharing options...
alucryd 216 Posted February 27 Share Posted February 27 Yes, at first the ICD loader was statically linked everywhere, it was later changed so we could potentially use the one from the system. Link to comment Share on other sites More sharing options...
