Cluttered 8 Posted January 28 Share Posted January 28 I have searched for subtitles before and it found a list of them, but recently all I get is “No results found. Have you configured…” In the log it shows a badrequest: 2024-01-28 16:09:14.546 Info HttpClient: POST https://api.opensubtitles.com/api/v1/login 2024-01-28 16:09:14.792 Error SubtitleManager: Error downloading subtitles from Open Subtitles *** Error Report *** Version: 4.7.14.0 Command line: /Applications/EmbyServer.app/Contents/MacOS/EmbyServer.dll Operating system: Darwin 21.6.0 Darwin Kernel Version 21.6.0: Sun Dec 17 22:55:27 PST 2023; root:xnu-8020.240.18.706.2~1/RELEASE_X86_64 Framework: .NET 6.0.21 OS/Process: x64/x64 Runtime: Applications/EmbyServer.app/Contents/MacOS/System.Private.CoreLib.dll Processor count: 4 Data path: /Users/Mark/.config/emby-server Application path: /Applications/EmbyServer.app/Contents/MacOS MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadRequest at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at OpenSubtitles.OpenSubtitleComDownloader.Login(OpenSubtitleOptions options, CancellationToken cancellationToken) at OpenSubtitles.OpenSubtitleComDownloader.Search(SubtitleSearchRequest request, OpenSubtitleOptions options, CancellationToken cancellationToken) at Emby.Providers.Subtitles.SubtitleManager.<>c__DisplayClass17_0.<<SearchSubtitles>b__3>d.MoveNext() Source: Emby.Server.Implementations TargetSite: Void MoveNext() I am running the server on an iMac under the latest Monterey version, I can login to opensubtitles.com fine, I have a free account, if I look under the download history it’s all zero. I don’t have anything under api consumers either but I don’t think I should have. I saw in the setup a link to check banned downloads so I clicked that and got: Global (system) download limit: 200 per 24 hours Detected IP(s): Array Raw IPs: <removed> Detected Country: gb BANNED: No User Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.3 Safari/605.1.15 Accept Language: en-GB,en;q=0.9 FINAL RESULT: Accepting download You are not logged-in on OpenSubtitles.org SYSTEM should count downloads by IP ADDRESS(es) ========================================== List of downloaded subtitles per IP: <removed> for last 24 hours - total 0 Array ( ) You can download 200 subtitles more ========================================== Anyone have any ideas? Link to comment Share on other sites More sharing options...
Solution Cluttered 8 Posted January 28 Author Solution Share Posted January 28 Ah, sorted it, my account was set to use the email, that was what I set it up with originally and has worked. I tried it with the username instead and now it works. 1 1 Link to comment Share on other sites More sharing options...
