runner041 2 Posted January 6 Share Posted January 6 Hello, Before my m.2 ssd cache upgrade, both were the same. How to make the change for the emby lan ip server address? Thanks. Link to comment Share on other sites More sharing options...
Luke 37116 Posted January 6 Share Posted January 6 Hi, what do you mean by both? Can you show us exactly what you mean? Thanks. Link to comment Share on other sites More sharing options...
runner041 2 Posted January 6 Author Share Posted January 6 Problem solved. Thanks Link to comment Share on other sites More sharing options...
Luke 37116 Posted January 6 Share Posted January 6 47 minutes ago, runner041 said: Problem solved. Thanks What was the solution? Link to comment Share on other sites More sharing options...
runner041 2 Posted January 7 Author Share Posted January 7 1 hour ago, Luke said: What was the solution? It seems that the emby app matched both ips after a while. With qnap boxes one must be patient at all time. Link to comment Share on other sites More sharing options...
Luke 37116 Posted January 7 Share Posted January 7 You also could have just manually entered the new ip address into the Emby app by adding a new server. Link to comment Share on other sites More sharing options...
runner041 2 Posted January 7 Author Share Posted January 7 Exactly. I thought about it but i wasnt sure it would work. 1 Link to comment Share on other sites More sharing options...
