mskenny 7 Posted December 25, 2022 Share Posted December 25, 2022 I'm having trouble logging in from a Roku Streaming Stick 4K. I can connect via PIN through https://emby.media/pin. Then when I select "Connect to server" then click on the username on the Select Server screen, I just get an endless spinning wheel. If I try a manual connection, I get the error in the attached screen shot "We're unable to connect right now...-60: SSL certificate problem :unable to get local issues certificate" I have a valid certificate issued by GoDaddy. I can login fine on the iOS app or via a browser. I've attached the Emby logs. This is a model 3820X - Streaming Stick 4K running 11.5.0 build 4312Embyserver.txt.pdf -CU. Thank you. Link to comment Share on other sites More sharing options...
ebr 14913 Posted December 25, 2022 Share Posted December 25, 2022 Hi. Make sure the remote address shown on your dashboard is using the domain name for which your certificate is issued. If you manually enter the server address, does it connect then? Link to comment Share on other sites More sharing options...
mskenny 7 Posted December 25, 2022 Author Share Posted December 25, 2022 It is the same address. I tried manually entering the domain name (https://domain) and port and that's when I get the "-60" error. Link to comment Share on other sites More sharing options...
speechles 1917 Posted December 25, 2022 Share Posted December 25, 2022 (edited) You can possibly omit the port number. Host: "https://yoursite.com" Port: "00000" Doing the above will let your domain redirect to the proper port. Maybe that is the problem? Edited December 25, 2022 by speechles Link to comment Share on other sites More sharing options...
mskenny 7 Posted December 25, 2022 Author Share Posted December 25, 2022 Thanks. I'll give this a try later. Link to comment Share on other sites More sharing options...
Luke 37065 Posted December 26, 2022 Share Posted December 26, 2022 Let us know how you get on. Thanks. Link to comment Share on other sites More sharing options...
mskenny 7 Posted December 26, 2022 Author Share Posted December 26, 2022 I tried putting in the domain name preceded by https:// and using 0000 for the port. I tried the domain name without "https://" and I tried basically every combination I could think of but nothing worked. I tried logging out of Emby Connect and logging in with PIN again and I can login but, again, when I try to connect after logging in I just get a spinning wheel and the log just shows the same errors as the one I previously uploaded. I tested the connection from a Samsung smart TV in the same home and it works fine. I'm not sure what else to try. Link to comment Share on other sites More sharing options...
ebr 14913 Posted December 26, 2022 Share Posted December 26, 2022 Hi. That error implies to me that the Roku does not trust the certificate. You said you got it through GoDaddy? Link to comment Share on other sites More sharing options...
mskenny 7 Posted December 26, 2022 Author Share Posted December 26, 2022 Yes. Here are photos of the certificate info taken from a windows computer (since IPad OS won't show this data to me.) Link to comment Share on other sites More sharing options...
Luke 37065 Posted January 14, 2023 Share Posted January 14, 2023 @mskenny are you still having an issue with this? Link to comment Share on other sites More sharing options...
mskenny 7 Posted January 14, 2023 Author Share Posted January 14, 2023 The Roku stick in question is at my sister's home where I was spending the holidays, so I can't test it. I will see if I can get my sister to try it. Link to comment Share on other sites More sharing options...
Luke 37065 Posted January 19, 2023 Share Posted January 19, 2023 Were you able to try? Link to comment Share on other sites More sharing options...
Robert Smith 1 Posted January 23, 2023 Share Posted January 23, 2023 (edited) I am having the exact same problem. Digicert certificate, certificate is valid, I am able to connect with laptop fine, but roku gives me the error mentioned above. Edited January 23, 2023 by Robert Smith Link to comment Share on other sites More sharing options...
mskenny 7 Posted January 24, 2023 Author Share Posted January 24, 2023 I asked my sister to try logging in and she was successful. 1 Link to comment Share on other sites More sharing options...
Luke 37065 Posted January 30, 2023 Share Posted January 30, 2023 On 1/22/2023 at 7:29 PM, Robert Smith said: I am having the exact same problem. Digicert certificate, certificate is valid, I am able to connect with laptop fine, but roku gives me the error mentioned above. @Robert Smith are you sure your certificate hasn't expired? Link to comment Share on other sites More sharing options...
Robert Smith 1 Posted February 8, 2023 Share Posted February 8, 2023 100℅ certain, in faxt I generated a new one with same results. Link to comment Share on other sites More sharing options...
ebr 14913 Posted February 8, 2023 Share Posted February 8, 2023 Are you sure it is trusted by the Roku device? Link to comment Share on other sites More sharing options...
Robert Smith 1 Posted February 8, 2023 Share Posted February 8, 2023 Hi ebdr, how can I tell if it is trusted by the device? I am happy to share my server ip and one of you guys can look at the cert. Link to comment Share on other sites More sharing options...
ebr 14913 Posted February 9, 2023 Share Posted February 9, 2023 19 hours ago, Robert Smith said: Hi ebdr, how can I tell if it is trusted by the device? I am happy to share my server ip and one of you guys can look at the cert. Hi. Are you still getting that original error indicating a certificate problem? That would indicate the Roku does not trust it. Link to comment Share on other sites More sharing options...
Robert Smith 1 Posted February 11, 2023 Share Posted February 11, 2023 (edited) Yes still getting the same problem. If Roku does not trust it, then how do I fix the issue? I have no issues with Roku trusting certificates on Plex. In platforms other than roku, it logs me off and then it hangs sinning trying to get it. I hate comparing platforms, there is so much that I love about Emby but not being able to connect reliably is a problem. There are many other posts in the forum about similar issues and it always comes down to someone elses fault. But here is the thing, Plex got that part right, connecting is not a problem. Perhaps the emby team needs to spend some time perfecting basic functionality. You could be 100 percent correct hat Roku is the problem, but not looking for a way to overcome what ever is causing roku to complain is not the right solution. Edited February 11, 2023 by Robert Smith Link to comment Share on other sites More sharing options...
ebr 14913 Posted February 11, 2023 Share Posted February 11, 2023 12 hours ago, Robert Smith said: Plex got that part right, connecting is not a problem Hi. Yes, when you force people to go through your central servers to access theirs, then that gives you a lot of control over how connections happen. We chose not to take that route which does put more responsibility on the individual installation. We are always searching for ways to make this easier - without taking complete control of your connections and users. Thanks. Link to comment Share on other sites More sharing options...
doonze 30 Posted February 14, 2023 Share Posted February 14, 2023 I have certs though letsencrypt, and never had a problem there. However, running apache (and a reverse proxy), in any Emby app outside my home (roku included), people have to make the port 0000. I think using 443 also works, but that was many many moons ago. I use Google domains, and dynamic DNS so your experience may vary. IIRC no matter what I did, Google redirected my domain to either 80 (http) or 443 (https) no matter what you did with ports in the address. So can't use ports. And it's better anyway, my reverse proxy handles the ports, and all anyone has to remember is https://emby.mydomain.net and they are golden. Plus no open ports on my router. But the trick is using 0's or 443 in the port number (if your using certs). Just dropping this here as this title could get lots of hits when searching. 1 Link to comment Share on other sites More sharing options...
Luke 37065 Posted April 27, 2023 Share Posted April 27, 2023 @mskenny Hi, are you still having an issue with this? Link to comment Share on other sites More sharing options...
mskenny 7 Posted April 27, 2023 Author Share Posted April 27, 2023 The Roku in question is at my sister's home and she reports that she is able to login. I have no issue with the Roku Ultras in my home. Thanks. 1 Link to comment Share on other sites More sharing options...
