JeremyFr79 228 Posted October 16, 2013 Share Posted October 16, 2013 Ok so I have an Xbox 360 running as extender, MBC works great in it, but there's no way to setup auto login for the extender since you can't log into your PC with the extender account to access configurartor. Would there be any other way of setting up auto login so I don't have to select a user etc, each time I launch MBC on an extender? Hope I was clear in explaining this.... Link to comment Share on other sites More sharing options...
Solution ebr 14913 Posted October 16, 2013 Solution Share Posted October 16, 2013 For now I have a hack for you. Set up the auto-login on the PC and then copy the common xml file to the extender user's appdata directory. 1 Link to comment Share on other sites More sharing options...
JeremyFr79 228 Posted October 17, 2013 Author Share Posted October 17, 2013 Worked perfect, you're a lifesaver! Link to comment Share on other sites More sharing options...
Abobader 2945 Posted October 17, 2013 Share Posted October 17, 2013 Please accept Ebr answer if that solve the issue for you. Link to comment Share on other sites More sharing options...
