runner041 2 Posted May 1, 2022 Share Posted May 1, 2022 I deleted the m3u link and xml link from live tv to add nextpvr plugin. I installed nextpvr, trying to login in nextpvr windows panel but login failed message as a result. So i uninstalled the plugin from emby. Then i reinstall the previous m3u link and xml link in live tv. Now i get emty tv guide when i click on tv guide. Thanks. embyserver.txt Link to comment Share on other sites More sharing options...
Luke 37066 Posted May 1, 2022 Share Posted May 1, 2022 Hi, what problem in Emby are you having? Link to comment Share on other sites More sharing options...
runner041 2 Posted May 1, 2022 Author Share Posted May 1, 2022 problem after installing the nextpvr plugin: the guide doesnt show up in emby live tv after uninstalling nextpvr. Link to comment Share on other sites More sharing options...
Luke 37066 Posted May 1, 2022 Share Posted May 1, 2022 What tuner sources and guide data did you setup in Emby live tv setup? Link to comment Share on other sites More sharing options...
runner041 2 Posted May 1, 2022 Author Share Posted May 1, 2022 (edited) m3u playlist source. Im able to watch tv. To see the guide by ch i must click on the ch tab. Edited May 1, 2022 by runner041 Link to comment Share on other sites More sharing options...
Luke 37066 Posted May 1, 2022 Share Posted May 1, 2022 Did you setup guide data? Link to comment Share on other sites More sharing options...
runner041 2 Posted May 1, 2022 Author Share Posted May 1, 2022 Yes i did. For sure the problem is with nextpvr plugin not compatible with emby. They should remove that plugin from the catalog. Link to comment Share on other sites More sharing options...
emveepee 112 Posted May 1, 2022 Share Posted May 1, 2022 The catalog version is for v4 of NextPVR. However you are also partially correct, since you are using the beta Emby server 4.7.0.36. As noted on the NextPVR subforum here the V5 addon you should be using from github and it is also end of life. Luke is working on an updated addon which supports the new Emby 4.7 model for reduced live TV integration with other applications. I assume it will be added to the catalog as the V4 addon will stop working completely. Martin Link to comment Share on other sites More sharing options...
Solution Luke 37066 Posted May 2, 2022 Solution Share Posted May 2, 2022 Actually if you're on 4.7 there is already a compatible version in the catalog so try installing the latest from there. Link to comment Share on other sites More sharing options...
ctine2020 0 Posted May 2, 2022 Share Posted May 2, 2022 (edited) I got this to work Edited May 2, 2022 by ctine2020 Link to comment Share on other sites More sharing options...
Luke 37066 Posted May 2, 2022 Share Posted May 2, 2022 Thanks for the feedback. Link to comment Share on other sites More sharing options...
runner041 2 Posted May 2, 2022 Author Share Posted May 2, 2022 18 hours ago, emveepee said: The catalog version is for v4 of NextPVR. However you are also partially correct, since you are using the beta Emby server 4.7.0.36. As noted on the NextPVR subforum here the V5 addon you should be using from github and it is also end of life. Luke is working on an updated addon which supports the new Emby 4.7 model for reduced live TV integration with other applications. I assume it will be added to the catalog as the V4 addon will stop working completely. Martin How to download nextpvr v5 from github? Thx Link to comment Share on other sites More sharing options...
