kornster 5 Posted September 16, 2014 Posted September 16, 2014 Hi All, Does anyone know if there is a release on the way for the ROC theme and the latest build of MB Classic (Currently for me Version 3.0.5366.22005). I purchased and have been using the ROC theme for about 5 months or more now and ive noticed with the last few releases of Server and MB Classic that the theme has gotten less and less responsive (Apologies Lee). It used to work really well and then my wife start raging one day when i updated it that "Recently Added" was broken and when i checked it, it would present a message after some time "Program not responding" and then crash MB3 back to WMC. We also have issues navigating around the theme as well for either movies or tv series with a huge 30 second delay in moving from one title to the next. Is there a plan to update/resolve some of the issues that ive been seeing with this theme. I'm currently using Chocolate to meet our needs but my wife wants ROC back. Not sure if this is related but we are using a Logitech Harmony 1000 remote to use with WMC. Regards Danny
kornster 5 Posted September 16, 2014 Author Posted September 16, 2014 Oh i almost forgot. The new Player Interface that recently got implemented. If thats enabled and i run ROC. MB3 refuses to work at all. If i disable it in the Config menu then ROC will load. Cheers
Solution kornster 5 Posted September 17, 2014 Author Solution Posted September 17, 2014 This issue is now resolved. I was doing some work on it yesterday and came across and issue with users using BitDefender AV and it causing all sorts of issues in their media center`s. I uninstalled BitDefender AV and installed MSE and the theme and recently added issues are now non existent. Uninstalling BitDefender also resolved a whole heap of other issues i had with the Media Center and applications on there. BitDefender seems to do some really strange things with applications. On my main PC i have to disable BD to run any games from Steam. I might go back to BD and ask them to explain. Regards Danny
