geekinthesticks
ffmpeg Using 100% CPU.
geekinthesticks
I have just discovered MediaBrowser and decided to try it out on my laptop. I am using ArchLinux and running the latest version from the AUR repo. I got it installed and setup OK. However, when I try to view a video it won't play. Looking at top ffmpeg is using all my CPU, presumably trying to transcode the video.
If I drag the slider through the video, I can preview the snap shot OK. The laptop is a core i5 with 8GB RAM and I have tried various videos - mostly mp4 either from a GoPro, or transcoded via Handbrake using the Android profile. The computer can play the same videos back using VLC.
I am using Chromium.
Share this post
Link to post
Share on other sites
JonnyLH
What is top saying exactly? When I transcode 1080p/30mbps I get around 250% on top on a 2nd gen I3 which is 62.5% of the CPU. Keep in mind that each core represents 100% CPU in top.
Share this post
Link to post
geekinthesticks
I am getting 190-250%, which presumably means that 2 cores are being used. The videos I have tried are all less that 1080p and are 25fps h264. When I try to play the video, I just get a black screen, or the first frame of the video and ffmpeg is churning away in the background.
I have also installed Plex on the same computer and it can play back the videos OK.
Edited by geekinthesticks
Share this post
Link to post
JonnyLH
That's weird. To be honest, I think it will rack up the same amount of CPU usage unless it's struggling to hit it real-time. The variable is the frame rate its transcoding at.
What device are you using to stream it? Is there any errors in the logs when your hitting the stream?
Share this post
Link to post
