ITGuy1024 13 Posted August 6, 2021 Share Posted August 6, 2021 We have a Roku at our vacation house. I'm trying to set it up to access my Emby server. When I do the manual setup with the IP and user credentials it logs in fine but never saves the information. I don't see any place to click save so I have to keep entering the IP, username and password over and over. Thoughts? Link to comment Share on other sites More sharing options...
Luke 37269 Posted August 7, 2021 Share Posted August 7, 2021 Hi, did you explore the settings in the app related to remembering login? Link to comment Share on other sites More sharing options...
ITGuy1024 13 Posted August 7, 2021 Author Share Posted August 7, 2021 Yeah, remember login was selected. I unchecked it and checked it again with no change. Link to comment Share on other sites More sharing options...
ebr 14960 Posted August 7, 2021 Share Posted August 7, 2021 Hi. Exactly what happens when you come back to the app? It sounds like maybe the login is failing so check to be sure that the dashboard of your server is showing the proper WAN address for connecting from that location. Link to comment Share on other sites More sharing options...
Solution speechles 1929 Posted August 7, 2021 Solution Share Posted August 7, 2021 You can also delete all the Roku device that show up in the devices tab of your Emby server. Once you do this connect to the Roku and login. Now turn remember me to NO and exit the application. This should force it to destroy all tokens. Now log back in and set remember user to YES and it should now stick. You can press HOME and confirm this. Let us know if this helps or not. Thanks. Link to comment Share on other sites More sharing options...
ITGuy1024 13 Posted August 7, 2021 Author Share Posted August 7, 2021 1 hour ago, speechles said: You can also delete all the Roku device that show up in the devices tab of your Emby server. Once you do this connect to the Roku and login. Now turn remember me to NO and exit the application. This should force it to destroy all tokens. Now log back in and set remember user to YES and it should now stick. You can press HOME and confirm this. Let us know if this helps or not. Thanks. This was it I think. I found an article on here last night about removing the device on the Devices page and trying it again. Link to comment Share on other sites More sharing options...
