chrillerb 0 Posted August 3, 2021 Share Posted August 3, 2021 Hi there, Just installed Emby on my WD My Cloud Mirror (2nd gen). And it seems like the server is running. Problem is though: I cannot login to the server. Tried using my Emby-login from another server - without any luck. And I don't have the password for the user suggested as a standard. I tried selecting "forgot password" - but then a text file is sent to somewhere on the WD My Cloud that I cannot acces ... Any ideas what I'm doing wrong? Link to comment Share on other sites More sharing options...
Luke 37144 Posted August 4, 2021 Share Posted August 4, 2021 Quote Tried using my Emby-login from another server The users are private to each server. Do you recall the username and passwords you setup on that server? Link to comment Share on other sites More sharing options...
chrillerb 0 Posted August 7, 2021 Author Share Posted August 7, 2021 Hi Luke - thanks for replying. During the install process of Emby on the WD I do not get to choose a username/password. So I really don't know what it is setup to be. Tried using same username/password as for the WD - but without any luck. Link to comment Share on other sites More sharing options...
Luke 37144 Posted August 16, 2021 Share Posted August 16, 2021 It's what you previously set it up to be. What most likely happened is you installed emby server, setup a username and password, then uninstalled. When you uninstall, the server's data folder is not removed, so after reinstalling, you need to login with the same credentials that you setup the first time. If you've forgotten what that is, please try using the forgot password function and let us know if that helps. Thanks. Link to comment Share on other sites More sharing options...
Luke 37144 Posted August 16, 2021 Share Posted August 16, 2021 @cayars can you point to the recent similar topic of a western digital user who wanted to delete the data directory to make a fresh start? Thanks. Link to comment Share on other sites More sharing options...
Carlo 4330 Posted August 16, 2021 Share Posted August 16, 2021 On 8/3/2021 at 6:41 AM, chrillerb said: Hi there, Just installed Emby on my WD My Cloud Mirror (2nd gen). And it seems like the server is running. Problem is though: I cannot login to the server. Tried using my Emby-login from another server - without any luck. And I don't have the password for the user suggested as a standard. I tried selecting "forgot password" - but then a text file is sent to somewhere on the WD My Cloud that I cannot acces ... You should be able to get to the file using SSH or putty. Check out this WD article on using SSH for your NAS https://support-en.wd.com/app/answers/detail/a_id/26497/kw/winscp#subject3 Link to comment Share on other sites More sharing options...
Luke 37144 Posted August 17, 2021 Share Posted August 17, 2021 @chrillerb please let us know if this helps. Thanks. Link to comment Share on other sites More sharing options...
