Drew333 0 Posted November 28, 2015 Share Posted November 28, 2015 Hello all, I am having trouble getting live TV to work with Emby. I have Emby (3.0.5781.3) on Ubuntu Server (14.04) with TVHeadend Server (4.0.7), and the TVHeadend plugin for Emby (TVHclient 1.0.5628.29938). I have TVHeadend server setup with my channels, and the network streams work in VLC using the channel URL. I created a user in the access entry named "emby" with a password, and it works because I tested with VLC. When I put the settings into the TVHclient plugin on Emby, it shows the status as "OK". Emby doesn't show any channels on the live TV tab. Am I doing something wrong? Is there a better server for LiveTV setup on linux? Link to comment Share on other sites More sharing options...
Solution Vidman 589 Posted November 29, 2015 Solution Share Posted November 29, 2015 Do your channels have channel numbers assigned in tvheadend, the emby plugin will only import channels with channel numbers assigned 1 Link to comment Share on other sites More sharing options...
Drew333 0 Posted November 29, 2015 Author Share Posted November 29, 2015 Do your channels have channel numbers assigned in tvheadend, the emby plugin will only import channels with channel numbers assigned Yes, I have several channels with the proper names that it pulled in. Link to comment Share on other sites More sharing options...
Drew333 0 Posted November 29, 2015 Author Share Posted November 29, 2015 It looks like it is working now. Thank you for the help. Are there any other free alternatives for Linux available? And what is the best way to get TV guide data? Link to comment Share on other sites More sharing options...
