Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Video
  3. Tone mapping
  4. Tone-mapping curves
  5. General-purpose curves
  6. Reinhard
Search Results for
    Show / Hide Table of Contents
    Tone Mapping Curve: Reinhard
    Reinhard is a tone mapping curve that compresses increasingly bright values into a limited output range.
    Start with the simple relationship T(x) = x/(1+x) for an already scaled linear-light input. At small x, the denominator is near one. As x grows, the denominator grows too, making further input increases contribute less output.
    Input x Basic output Output after normalization to peak 8
    0.1 0.0909 0.1023
    1 0.5000 0.5625
    4 0.8000 0.9000
    8 0.8889 1.0000
    The basic function approaches one gradually. At a finite source peak of eight, its endpoint is eight-ninths. Multiplying by nine-eighths makes that known peak reach one and also raises the other mapped values.
    FFmpeg Reinhard mapping normalized to source peak eight, with a lower-input close-up.
    FFmpeg 8.1, public parameter 0.5, source peak 8, output white 1, relative linear light for neutral gray. Dashed gray shows clipping.
    Highlight compression and lower-tone brightness
    Inputs 4 and 8 are four units apart, but the normalized outputs differ by only 0.1. The values remain ordered and distinct; much less output contrast separates them. An input of one moves to 0.5625, showing that this mapping also changes ordinary levels.
    Uniform division by eight would put the same input of one at 0.125. The nonlinear relationship spends more of the output on the lower region and compresses the top more strongly. That is the actual compromise visible in the plot.
    Distinguish the curve from the complete photographic operator
    Reinhard and coauthors' original photographic tone-reproduction work also includes exposure scaling and a spatially varying method. A global function called Reinhard in a video filter represents one part of that family, with its own parameter and peak convention.
    FFmpeg's stated parameter corresponds to the normalized function in the table. In general its scalar form is x/(x+k) × (P+k)/P, with k derived from the public parameter. Changing k or P changes the mapping even before surrounding color operations.
    When comparing an Emby conversion, identify the actual curve implementation and normalization, then inspect both ordinary objects and highlight texture. The arithmetic here explains their relative placement rather than assuming the historical photographic method and a video option produce identical pictures.
    See Also
    • What a Tone-Mapping Curve Controls
    • How HDR-to-SDR Tone Mapping Works
    • Tone Mapping Curve: Mobius
    References
    • Reinhard, Stark, Shirley and Ferwerda: Photographic Tone Reproduction for Digital Images (2002)
    • Photographic Tone Reproduction for Digital Images: paper PDF
    • FFmpeg 8.1: tonemap implementation
    On this Page
    Back to Top
