Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Video
  3. Frame timing and interlacing
  4. Frame rates
  5. Variable frame rate
Search Results for
    Show / Hide Table of Contents
    Variable Frame Rate
    Variable frame rate allows the interval between successive video pictures to change.
    The four pictures below begin at 0, 40, 60, and 120 ms. Let the last picture remain visible until 160 ms.
    Picture Starts at Ends at Duration
    A 0 ms 40 ms 40 ms
    B 40 ms 60 ms 20 ms
    C 60 ms 120 ms 60 ms
    D 120 ms 160 ms 40 ms
    Their intervals vary. This is variable frame rate (VFR): the timeline carries the presentation schedule rather than describing every picture with one common duration.
    A constant-rate timeline has even spacing, while an illustrative variable-rate timeline has unequal spacing.
    The variable picture starts match the table. The added 160 ms endpoint defines the complete example's final hold.
    What the player does
    The player shows A until 40 ms, B for the next 20 ms, then C for 60 ms. Audio continues along the same timeline. A new video picture need not arrive on every screen refresh; the current picture can remain visible until the next timestamp.
    A screen recording can exploit this to retain a picture longer while the screen is static. A camera or edited sequence can produce VFR for other reasons. The timestamp schedule, rather than an assumed capture strategy, defines the representation.
    The average hides the intervals
    There are four pictures across 0.160 second:
    4 ÷ 0.160 = 25 pictures/s on average.
    Four equal 40 ms pictures over the same interval also average 25 fps. One sequence is variable and one is constant, even though their count, duration, and average match.
    A stream inspector can consequently show a reasonable average while picture-level timestamps reveal uneven intervals. This is useful for an Emby home video whose timing changes during conversion: compare the actual starts and durations, rather than only the rate field in a summary.
    Convert to a constant schedule
    A 25 fps output needs starts at 0, 40, 80, and 120 ms. One illustrative policy chooses the source picture currently visible at each output instant:
    Output instant Source picture selected
    0 ms A
    40 ms B
    80 ms C
    120 ms D
    The output still lasts 160 ms, but the transition to C now occurs at 80 ms instead of 60 ms. In a longer sequence, some source pictures may be repeated or omitted. A converter can use a different selection policy or interpolation, so its exact visible changes depend on that policy.
    The important point is that output pictures are chosen against the existing timeline. Duration and audio timing can remain intact even though the picture allocation changes.
    Retiming every picture is another operation
    If those same four pictures are instead each assigned 1/30 second, the sequence lasts 133.33 ms. The old presentation schedule has been replaced. Audio and subtitles following the original 160 ms timeline will no longer match without related retiming.
    Even assigning 40 ms to every picture, which preserves this example's total duration, moves its internal transitions. VFR carries those internal intervals as information. Preserving or changing them is a deliberate part of making a new video representation.
    See Also
    • Video Frame Rate
    • Fractional Frame Rates: 23.976, 29.97, and 59.94
    • Frame-Rate Conversion
    References
    • FFmpeg command-line documentation
    • FFprobe media inspection documentation
    On this Page
    Back to Top
