Audio Dynamic Range
Audio dynamic range describes a span of signal levels, with its meaning depending on whether the subject is a recording or a system.
You turn up a film to hear a whispered sentence, then turn it down when the next scene explodes. The soundtrack spans a wide range of programme levels. A device specification describing “dynamic range” asks a related but different question: how much usable level fits between its noise floor and its largest clean signal?
Volume and the 40 dB gap between passages
Suppose a loud event peaks at −2 dBFS and a quiet passage has a representative level of −42 dBFS. Those two selected levels are 40 dB apart. The quiet passage's amplitude is one hundredth of the peak amplitude, because 20 × log10(100) = 40 dB.
If both are lowered by 10 dB, they move to −12 and −52 dBFS. Their difference remains 40 dB. A volume control shifts the range; it does not narrow it.
A listener in a noisy room can therefore lose the quiet passage under the ambient sound while the peaks still sound loud. Playback gain, loudspeaker capacity, room noise, and the recording's dynamics all participate.
| Change | Effect on the selected levels |
| Lower overall gain by 10 dB | Both move down by 10 dB |
| Reduce loud sections more than quiet sections | The range narrows |
| Lower the system's noise floor | Quieter details can remain distinguishable |
| Add clean output headroom | Larger peaks can fit without overload |
A dialogue boost or dynamic-range processor can change the relationship between the chosen programme levels. That is the relevant mechanism for a night-listening option, rather than merely selecting another file bitrate.
Capacity and actual use
An integer PCM representation supplies a finite amplitude grid. Its quantization error sets one theoretical limit on usable low-level detail. More bit depth makes that grid finer; a real recording can encounter microphone or room noise before reaching that limit.
A soundtrack need not use all the available range. A heavily compressed mix can be stored at 24-bit precision, while another 24-bit mix may retain large contrasts. Bit depth describes capacity; the mix's level behavior describes its use.
A device's dynamic range is measured with a specified bandwidth, weighting, and test method. Those conditions belong with the quoted number. They differ from selecting two scenes and comparing their programme levels.
Peak-to-average behavior is another measurement
Crest factor compares peak amplitude with RMS amplitude over the same interval. A pure sine with peak 1 has RMS 1/√2, giving a crest factor of about 3.01 dB. A brief transient over a quiet background can have a much larger crest factor.
That does not by itself measure the contrast between an entire whisper scene and an explosion scene. Results change with the interval used, and a silence-heavy passage can produce a very different ratio from a dense one.
When interpreting a “DR” figure for music, identify its measurement method and selected time windows. For playback, decide whether the problem is background noise masking quiet material, overload at peaks, or an inconvenient contrast in the mix. Those lead respectively toward a quieter listening environment or noise floor, more clean headroom, or level-dependent processing.
