Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Audio
  3. Audio decoding and output
  4. Conversion and fallback
  5. Fallback to an embedded audio core
Search Results for
    Show / Hide Table of Contents
    Fallback to an Embedded Audio Core
    Core fallback plays an existing compatible audio component when the full presentation is unavailable.
    The selected soundtrack says DTS-HD Master Audio, but an older receiver detects DTS. An existing compatible core can explain this result: the player delivered the part that the receiver understands while omitting the enhancement information.
    Core fallback uses already encoded data. It differs from making a new codec version during playback.
    Extracting the existing DTS core
    A common DTS-HD disc stream has a core and extensions. The core is independently decodable; the appropriate full decoder uses the additional information for its enhanced or lossless presentation.
    If the output needs conventional DTS, a supported extraction route can retain the core's coded data. That result has the losses already present in the core, but avoids another lossy encoding generation.
    Route Origin of the delivered audio
    Extract existing core Coded component from the selected stream
    Choose another soundtrack Separately stored track/presentation
    Decode and transcode New encoded data from reconstructed audio
    A source can remain fully intact in the library while only one compatible component is used in the session.
    Describe what the fallback omitted
    A core may have fewer channels or lack lossless correction and spatial information used by the full presentation. The receiver's successful DTS decode therefore establishes that a compatible soundtrack arrived, not that the original Master Audio or DTS:X result was reconstructed.
    The lossless-correction example in Master Audio shows why the core alone differs from the corrected result.
    Establish that a core actually exists
    DTS defines extension-only arrangements too. An extraction operation cannot manufacture a missing core from such a stream; it would need another source presentation or a conversion.
    The Dolby cases also have different structure. TrueHD can be accompanied by separate/packaged AC-3 compatibility audio, but it does not contain the common DTS-HD-style lossy core. An E-AC-3 independent substream is independent within E-AC-3, not automatically an AC-3 component.
    For an Emby playback report, identify the selected source's actual components and the delivered codec. If a decoder/encoder created new AC-3 from the full source, call that transcoding, even if its final label resembles a familiar fallback. Naming the operation accurately explains both the preserved source and the presentation heard.
    See Also
    • DTS Core Audio
    • DTS-HD Master Audio
    • Dolby TrueHD Audio
    • Audio Transcoding
    References
    • ETSI TS 102 114 V1.6.1: DTS Coherent Acoustics core and extensions
    • DTS: Production tools and backwards compatibility
    • Dolby: TrueHD lossless audio
    • Dolby: Dolby Digital Plus audio coding
    On this Page
    Back to Top
