Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Audio
  3. Audio decoding and output
  4. Audio/video synchronization
Search Results for
    Show / Hide Table of Contents
    Audio/Video Synchronization
    Audio/video synchronization aligns sound and picture on a common playback timeline while accounting for their different delays.
    A clap is easy to use as a synchronization check: the hands meet at a visible instant, and the matching sound has an identifiable attack. If those events are separated, first observe whether the gap stays constant or grows.
    Synchronization aligns presentations on a common timeline, then accounts for different processing and output delays.
    Convert each stream's time units
    Video frames and audio sample blocks need not arrive together or represent equal durations. Their timestamps say when the reconstructed results belong in the presentation.
    For an illustrative timebase conversion:
    Stream timestamp Unit duration Presentation time
    Audio: 960,000 1/48,000 second 20 seconds
    Video: 500 1/25 second 20 seconds
    The numbers differ by nearly three orders of magnitude but designate the same instant. Comparing raw timestamp integers without their units would be meaningless.
    The decoder also needs its input early enough to produce the output for that instant. Decode order, buffering, and presentation scheduling are related but distinct jobs.
    Schedule around different output delays
    Suppose a picture path takes 100 ms from submission to display, while a sound path takes 20 ms to the audible output. To present both at a chosen wall-clock instant of 20.000 seconds:
    • Submit the picture at 19.900 seconds.
    • Submit the audio at 19.980 seconds.
    Submitting both at 19.900 would make the sound arrive at 19.920, 80 ms before the picture. Adding 80 ms of audio delay could compensate for that fixed difference.
    These are hypothetical processing delays, not universal television or player values. They show why equal submission/packet-arrival time is not synchronization.
    Separate fixed offset from clock drift
    A fixed offset can come from unequal processing paths, an initial timestamp difference, or an uncompensated encoder/filter delay. Delaying the earlier presentation can address that particular constant gap.
    A rate mismatch accumulates instead. A hypothetical audio device consuming 48,002.4 frames per wall-clock second instead of 48,000 runs 50 parts per million fast. Over one hour it consumes 2.4 × 3,600 = 8,640 additional frames, representing 0.18 seconds at the intended rate.
    Changing the starting delay does not remove the rate difference. A player can need clock tracking, scheduling changes, or appropriate rate conversion to keep the presentations aligned over time.
    Preserve the timeline through a seek or conversion
    A seek jumps the desired media time, but decoder buffers can still contain data from the previous position. The player must flush/reinitialize appropriate state and establish the new audio/video relationship.
    A transcoded track also has its encoder delay and final padding. Timestamps and trimming must account for them rather than making them extra audible programme time.
    These mechanisms explain why a file can start aligned and change after a seek, or why one delivery/output route differs from another.
    What the timing symptoms reveal
    Observation First useful comparison
    Same offset at beginning and end Compare fixed delays and starting presentation times
    Increasing mismatch Compare timebase interpretation, rates, and clocks
    Sudden change after seeking Compare seek/reset behavior
    Only one audio output affected Compare that output path's buffering and processing
    Same misplaced event on several paths Examine the source's timing/presentation
    For an Emby session, record the event, approximate gap, and whether it changes with time. A comparison through another client or output route then isolates a boundary. This is more useful than choosing an offset value before knowing whether the problem is an offset at all.
    See Also
    • Packet Timestamps
    • Time Bases
    • Video Frame Rate
    • The Audio Playback Path
    References
    • ITU-R BT.1359: Relative timing of sound and vision
    • RFC 3550: RTP timestamps and synchronization
    • FFmpeg: Audio filters, mixing, and delay
    On this Page
    Back to Top
